Problem instantiating MotorKit i2c
by Chiliarch on Sat Mar 13, 2021 12:55 pm
Hello
I have a MetroExpress M4 with a V2 MotorShield attached. Attempting to bring up the shield in circuitPython.
I'm going through the tutorial at: https://learn.adafruit.com/adafruit-ste ... cuitpython
The board is updated to the latest version of python, and I've downloaded the most current version of the various libraries involved.
The full code is exactly as in the tutorial, literally copy/paste.
I'm getting an error with the following line:
kit = MotorKit(i2c=board.I2C())
I've also tried it as:
kit = MotorKit()
REPL throws the following when I save to the board:
code.py output:
  File "code.py", line 9, in <module>
  File "/lib/adafruit_motorkit.py", line 64, in __init__
  File "/lib/adafruit_pca9685.py", line 141, in frequency
  File "adafruit_register/i2c_struct.py", line 70, in __get__
  File "adafruit_bus_device/i2c_device.py", line 155, in write_then_readinto
TypeError: extra keyword arguments given
FWIW, I've also checked i2c with the PCA 9685:
import board
i2c = board.I2C()
i2c.try_lock()
i2c.scan()
scan = i2c.scan()
for addr in scan:
    print("Adress = {0:3d}, Hex = {1}".format(addr, hex(addr)))
Any help is appreciated!
Chiliarch
Re: Problem instantiating MotorKit i2c
by Chiliarch on Sat Mar 13, 2021 1:35 pm
Further information: I unmounted the board, quit REPL and restarted everything. Now the code is taking, and I'm not getting the error I posted above. However, REPL goes out to lunch at the "kit = MotorKit(i2c=board.I2C())" line and never displays the second Print.
Here's the code I've loaded to the board, and the REPL response:
# SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries
# SPDX-License-Identifier: MIT
# """Simple test for using adafruit_motorkit with a stepper motor"""
import time
import board
from adafruit_motorkit import MotorKit
print("I am alive ")
print("I am still alive ")
# for i in range(100):
#    kit.stepper1.onestep()
#    time.sleep(0.01)
Response:
code.py output:
I am alive
At this point the board displays a steady green light and REPL does not CTRL+D.
Surely I'm making an error somewhere (?)
Chiliarch
by Chiliarch on Sun Mar 14, 2021 3:25 am
Pulled the latest (14MAR'21) libraries that posted this evening, and everything works fine. I must have caught things mid-update when I started in on it this morning. No need to reply - this appears to be resolved.
Chiliarch
