Python Plotting problem
by BillPretty on Sat Mar 13, 2021 7:02 pm
I am having problems with the following python script.
I see four graphs, but no data is plotted.
Code:
from gpiozero import CPUTemperature
from time import sleep, strftime, time
import matplotlib.pyplot as plt
import os
import busio
import digitalio
import board
import adafruit_mcp3xxx.mcp3008 as MCP
from adafruit_mcp3xxx.analog_in import AnalogIn
# create the spi bus
spi = busio.SPI(clock=board.SCK, MISO=board.MISO, MOSI=board.MOSI)
# create the cs (chip select)
cs = digitalio.DigitalInOut(board.D22)
# create the mcp object
mcp = MCP.MCP3008(spi, cs)
# create cpu object
cpu = CPUTemperature()
# Initialise the subplot function using number of rows and columns
figure, axis = plt.subplots(2, 2)
# create an analog input channel on pin 0
chan0 = AnalogIn(mcp, MCP.P0)
while True:
    x= time()
    # plot temperature
    temp = cpu.temperature
    axis[0,0].plot(x,temp)
    plt.draw()
    print ('Core Temperature:' + str(temp))
    plt.pause(1)
    # plot +5V
    adc=chan0.voltage
    axis[0,1].plot(x,chan0.voltage)
    plt.draw()
    print('ADC Voltage: ' + str(chan0.voltage) + 'V')
    plt.pause(1)
BillPretty
Re: Python Plotting problem
by adafruit_support_carter on Mon Mar 15, 2021 5:56 pm
Please don't cross post:
viewtopic.php?f=48&t=176762
