make BOARD=trinket_m0 fails with undeclared identifier
by Kangus on Fri Mar 19, 2021 11:56 am
Following https://learn.adafruit.com/building-cir ... cuitpython guide (and keeping track of the changes needed for Windows 10 WSL2) I ended up with:
kevin@Aorus:~/circuitpython/ports/atmel-samd$ make BOARD=trinket_m0
../../py/gc.c: In function 'gc_sweep':
../../py/gc.c:298:68: error: 'MP_QSTR___del__' undeclared (first use in this function)
298 | mp_load_method_maybe(MP_OBJ_FROM_PTR(obj), MP_QSTR___del__, dest);
../../py/gc.c:298:68: note: each undeclared identifier is reported only once for each function it appears in
make: *** [../../py/mkrules.mk:55: build-trinket_m0/py/gc.o] Error 1
Git was ran on 3/19/2021, downloaded toolchain 3/19/2021 gcc-arm-none-eabi-10-2020-q4-major-x86_64-linux.tar.bz2
python3 -V = Python 3.85
Kangus
Re: make BOARD=trinket_m0 fails with undeclared identifier
by tannewt on Fri Mar 19, 2021 3:38 pm
Try doing a `make BOARD=trinket_m0 clean` and then trying again. The QSTR dependency logic isn't perfect.
The Discord is a good place to get build help too: https://adafru.it/discord
tannewt
by Kangus on Fri Mar 19, 2021 7:40 pm
That worked! firmware.uf2 370176 bytes - The screen flashed white/black for 6~10 seconds and it was done.
Now I can start working on getting the worlds best MCU setup for circuitpython using the: MAX32630FTHR board.
Might add the 'clean' thing to the 'how to'.
Kangus
