Is it possible to use BLE advertisement type ADV_NONCONN_IND
by andreas_johnsen on Wed Mar 31, 2021 4:48 pm
Hei,
Is it possible to use BLE advertisement type ADV_NONCONN_IND (non-connectable, non-scannable, undirected) with CircuitPython?
I can switch between ADV_IND (connectable, scannable, undirected) and ADV_SCAN_IND (non-connectable, scannable, undirected) by setting the attribute 'connectable' of an Advertisement object to 'True' or 'False'. But haven't figured out if it is possible to use ADV_NONCONN_IND with CP.
In the source code of 'def start_advertising()' in https://github.com/adafruit/Adafruit_Ci ... _init__.py it look like there always will be a 'scan_response' before 'self._adapter.start_advertising()' is called. If none scan_reponse is passed as parameter to 'start_advertising()', one will be created before calling the adapter.
I'm using nRF52840 Dongle with CP ver 6.0.1
andreas_johnsen
Re: Is it possible to use BLE advertisement type ADV_NONCONN
by tannewt on Thu Apr 01, 2021 5:30 pm
The core can do it: https://github.com/adafruit/circuitpyth ... ter.c#L647
I think the library won't let you pass an empty scan_response. Changing this line to this would allow it:
if scan_response is None and len(advertisement_bytes) <= 31:
Want to try it and make a PR if it works? That'd allow you to pass `scan_response=b""`
tannewt
by andreas_johnsen on Fri Apr 02, 2021 3:09 pm
Thank you very much for the suggestion. I will try to make a PR if it works as intended.
andreas_johnsen
