GPIO Input Question
GPIO Input Question
by Sigma_San on Sat Apr 03, 2021 6:34 pm
I'm working on a project that involves a lot of buttons. Would it be possible to map multiple buttons to one M4 Express GPIO pin using CircuitPython?
Sigma_San
Re: GPIO Input Question
by danhalbert on Sat Apr 03, 2021 6:44 pm
There's several ways to do this. You use an external device that can support many pins and then ask it for their values:
I2C GPIO expanders: Look at the first few hits on this: https://www.adafruit.com/?q=expander&sort=BestMatch. We have CircuitPython drivers for these devices, and there are Learn Guides:
https://learn.adafruit.com/adafruit-aw9 ... led-driver
https://learn.adafruit.com/using-mcp230 ... cuitpython
shift registers: https://www.adafruit.com/?q=shift+regis ... =BestMatch. Also have libraries and Learn Guides:
https://learn.adafruit.com/74hc595
danhalbert
by Sigma_San on Sat Apr 03, 2021 6:48 pm
Is there a method that doesn't involve additional hardware?
Sigma_San
by danhalbert on Sat Apr 03, 2021 6:58 pm
You need a way to distinguish one button being pushed from another. Another trickier way is to add a chain of resistors to the buttons, and measure the voltage, which will vary based on which buttons are pressed. But that's still extra hardware
danhalbert
by danhalbert on Sat Apr 03, 2021 7:01 pm
danhalbert
by Sigma_San on Sat Apr 03, 2021 7:05 pm
So will the method with the resistors still work on GPIO pins?
Sigma_San
by danhalbert on Sat Apr 03, 2021 7:31 pm
With resistors you'd need a pin that can be analog, so you might want to use the button grids with or without diodes.
danhalbert
by Sigma_San on Sat Apr 03, 2021 7:33 pm
OK. Thanks!
Sigma_San
