Code readability
Code readability
by Kangus on Sun Apr 04, 2021 11:58 am
While working through 'Contribute to CircuitPython with Git and GitHub' I came across some code in the review section:
def blink_rate(self,rate):
    if not 0 <= rate <= 3:
        raise ValueError('Blink rate must be an integer in the range: 0-3')
     rate = rate & 0x03
     self.blink_rate = rate
It took me a few seconds to figure out why the original code was ask to be changed and the solution.
My first thought was:
    if rate not in range(4):
     rate = rate & 0x03
If the object of python is ease of use and readability the 'in range' method is way easier to read.
Next I tried inline assembly with 5 instructions... Circuitpython doesn't do inline assembly, didn't know that..
Kangus
Re: Code readability
by danhalbert on Sun Apr 04, 2021 1:08 pm
`range()` is a generator that generates successive values, and `in` looks for a value in an arbitrary sequence of values.
So for instance if you did:
if 1001 in range(500):
Python would test 1001 against 0, 1, 2, 3, ..., 499. The <= test, on the other hand, only makes at most two comparisons. The notation is the same as standard math notation: x <= a <= b.
danhalbert
by Kangus on Sun Apr 04, 2021 7:45 pm
My 'concept' of a range test and how pythons range works are not even close.
def blink_rate():
    rate = 2
        rate = rate & 0x03
if __name__ == '__main__':
    import timeit
    print(timeit.timeit("blink_rate()", setup="from __main__ import blink_rate"))
(test-env) C:\Users\Kevin\test-env>python ttest.py
0.0807116
def blink_rate():
    rate = 2
    rate = rate & 0x03
    import timeit
(test-env) C:\Users\Kevin\test-env>python ttest2.py
0.2249187
Kangus
