Rotate Mini 0.8" 8x8 LED in circuitpython?
by mevander on Mon Apr 05, 2021 9:00 am
Hey.
I'm testing the space invader tutorial to get used to circuitpython and the 8x8 LED matrix. After a copy-paste of the supplied code (and spending a long time trying to free up enough memory for the libraries needed) I got the LED matrix to work. However, the pattern is rotated 90 degrees. I was looking for a function to rotate it in the matrix library but didn't find anything? Any suggestions?
mevander
Re: Rotate Mini 0.8" 8x8 LED in circuitpython?
by blnkjns on Mon Apr 05, 2021 9:06 am
What software do you use? This site only shows Arduino code.
Stupid question, but why not rotate the whole assembly?
blnkjns
by mevander on Tue Apr 06, 2021 1:55 am
blnkjns wrote:What software do you use? This site only shows Arduino code.
I'm following the tutorial (https://learn.adafruit.com/trinket-slas ... ython-code) and according to the images it should work. I could rotate it but it will make the pendant a bit less nice I think and I also want to figure out why to do it :)
mevander
by blnkjns on Tue Apr 06, 2021 7:18 am
In that code you can just swap x and y here:
    if frame_count < len(animation):
        for x in range(x_pix):
            for y in range(y_pix):
                matrix.pixel(x, y, animation[frame_count][x][y])
blnkjns
by mevander on Sat Apr 10, 2021 12:28 am
Of course! Now I feel stupid. Thank you very much!
Switching it to
matrix.pixel(x, y, animation[frame_count][y][x])
did the trick!
mevander
