CircuitPython Pico RC0 and Rotary Encoder
by nevyn on Mon Apr 05, 2021 1:15 pm
I'm trying to get a rotary encoder working with the Pico and the CircuitPython 6.2.0 RC0. I'm following this page: https://learn.adafruit.com/rotary-encoder/circuitpython, basically the code is:
import rotaryio
import board
encoder = rotaryio.IncrementalEncoder(board.GP14, board.GP15)
last_position = None
while True:
    position = encoder.position
    if last_position is None or position != last_position:
        print(position)
    last_position = position
Saving to the board generates the following error:
  File "code.py", line 6, in <module>
ValueError: pull masks conflict with direction masks
Has anyone seen this problem before or have any advice?
Thanks in advance,
Mark
nevyn
Re: CircuitPython Pico RC0 and Rotary Encoder
by mikeysklar on Tue Apr 06, 2021 6:41 pm
Hi Mark,
I think we have another thread on this going.
viewtopic.php?f=60&t=176616&p=860422&hilit=pull+masks+conflict#p860422
Which two pins are you using? You might want to join in on the above link since it is the same issue.
mikeysklar
by nevyn on Wed Apr 07, 2021 1:50 am
I'll reply on the thread mentioned.
Thank you,
Mark
nevyn
