rfm9x LoRa board data send not working
by 0xdj on Mon Apr 05, 2021 6:10 pm
Hi, I'm curious if anyone has had any challenges with getting the rfm9x working in circuitpython for the Raspberry Pi module?
Im building a network of various LoRaHam devices, including a nicely working GPS module which does APRS-like things. my setup is:
    - Multiple feather m0 boards with 433mhz LoRa chipset (I'm in US but licensed). these can successfully send/recv to each other
    - Adafruit rfm9x raspberry pi board, installed and confirmed working screen, buttons, and recv LoRa on 434MHz
    - The above board, when attempting to send using
    rfm9x.send(bytes("hello","utf-8"))
    , data does not show up on any of the feathers
I can't work it out. The feathers happily send and receive data all day long, and all of this data is seen by the raspberry pi board. But it can't send a single packet. I can't identify where the issue may be... clearly on the right frequency and using all the right modulation/demodulation to pick up data transmitted from the M0 boards.
0xdj
Re: rfm9x LoRa board data send not working
by 0xdj on Mon Apr 05, 2021 6:30 pm
my Uniden radio scanner at least makes a noise when the rfm9x board is sending, so it's at least transmitting to the airwaves. Question is, why can none of the feather m0 boards see it then?
0xdj
by 0xdj on Mon Apr 05, 2021 6:38 pm
SOLVED!
rfm9x.enable_crc = True
The m0/radiohead requires CRC. From the examples, it looked like that was an optional setting, but it's not
For example, this tutorial: https://learn.adafruit.com/lora-and-lor ... lora-radio doesn't included the CRC line, so presumably it's fine for raspi<--->raspi, but once you want to talk with an m0 you need it.
0xdj
