Disable Auto-reload and restart on crash
by marcusone on Mon Apr 05, 2021 10:21 pm
I would like to disable Auto-reload (I don't want the device to restart on file changes, only when I CTRL-D or whatever is then needed).
Also, how can I get the board to auto restart after a crash? (MatrixPortal). Watchdog code in the docs doesn't seem to work.
Thank you!
marcusone
Re: Disable Auto-reload and restart on crash
by dastels on Tue Apr 06, 2021 10:44 am
You can disable auto-reload on file changes from the REPL:
>>> import supervisor
>>> supervisor.disable_autoreload()
You will have to manually restart CircuitPython when you update code, however, by using CTRL_D. You can re-enable autoreload in a similar fashion:
>>> import supervisor
>>> supervisor.enable_autoreload()
Restarting after a crash... not sure as it will output the error and backtrace and drop you into the REPL.
dastels
by tannewt on Tue Apr 06, 2021 11:57 am
Restarting after a Python exception can be done with a top level try/except clause that catches all exceptions.
tannewt
by marcusone on Wed Apr 07, 2021 5:06 pm
Thank you! of course its a simple solution, i was thinking too hard about how to restart from a crash :) too used to C where it just panics and reboots.
marcusone
