I'm using and ESP8266 and trying to interface with an INA260 both from adafruit. I'm using this version of circuitpython:
Adafruit CircuitPython 3.1.2 on 2019-01-07; ESP module with ESP8266
I'm trying to use the ina260simpletest.py example. If this is the wrong code to use please point me to the right code. These are the files that I have imported into the ESP8266:
>>> os.listdir('.')
['boot.py', 'umqttsimple.py', 'main.py', 'adafruit_ina260.py', 'i2c_device.py']
This is what the board module contains:
>>> dir(board)
['ADC', 'GPIO16', 'GPIO14', 'SCK', 'GPIO12', 'MISO', 'GPIO13', 'MOSI', 'GPIO15', 'GPIO2', 'GPIO0', 'GPIO4', 'SDA', 'RX', 'TX', 'GPIO5', 'SCL']
When I type in the ina260 sample code, I get this error:
>>> import board
>>> import adafruit_ina260
>>> i2c = board.I2C()
File "<stdin>", line 1, in <module>
AttributeError: 'module' object has no attribute 'I2C'
I've seen that this problem might be fixed and there is an updated board.py. I've imported that file, but I don't see any updated in the board module. board.I2C is still missing.
What do I need to do to get this fixed?
I choose the ESP8266 because I need wifi connections to use MQTT to connect to other ESP8266's and an RPI Zero W MQTT broker. Should I be using a different feather board?
