Question with dual RXUART via pio on Pico
by adechiaro on Thu Apr 08, 2021 8:07 pm
Hello! I'm trying to leverage the example RXUART pio implementation on a Pico to pull in data from 2x PM2.5 sensors.
My example works fine for a single UART, but when I try 2 it seems there are some issues with timing or synchronization. Posting the question here, as I'm definitely new to the Pico and concept of PIO, seeing if anyone has some suggestions.
This code fails to find the header at the start, but it seems data is being captured at least somewhat correctly ('BM' is present, just not at the start). I could hack around this by shifting the array, but figured I'd see if there was something I was overlooking first.
code.py output:
created uart <RXUART at board.GP2>
created uart <RXUART at board.GP4>
error decoding data:
bytearray(b'\x00\x00\x00\x00\x00\x97\x00\x01\xf6BM\x00\x1c\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00!\x00\n\x00\x02\x00')
  File "code.py", line 109, in <module>
  File "code.py", line 76, in __init__
InvalidDataError:
# SPDX-FileCopyrightText: 2021 Jeff Epler, written for Adafruit Industries
import rp2pio
import adafruit_pioasm
import board
import time
from adafruit_binascii import hexlify, unhexlify
code = adafruit_pioasm.assemble(
.program uart_rx_mini
; Minimum viable 8n1 UART receiver. Wait for the start bit, then sample 8 bits
; with the correct timing.
; IN pin 0 is mapped to the GPIO used as UART RX.
; Autopush must be enabled, with a threshold of 8.
    wait 0 pin 0        ; Wait for start bit
    set x, 7 [10]       ; Preload bit counter, delay until eye of first data bit
bitloop:                ; Loop 8 times
    in pins, 1          ; Sample data
    jmp x-- bitloop [6] ; Each iteration is 8 cycles
class RXUART:
    def __init__(self, pin, baudrate=9600):
        self.pin = pin
        self.pio = rp2pio.StateMachine(
            code,
            first_in_pin=pin,
            frequency=8 * baudrate,
            auto_push=True,
            push_threshold=8,
    def __str__(self):
        return '<RXUART at {0}>'.format(self.pin)
    @property
    def timeout(self):
        return 0
    @property
    def baudrate(self):
        return self.pio.frequency // 8
    @baudrate.setter
    def baudrate(self, frequency):
        self.pio.frequency = freqency * 8
    @property
    def in_waiting(self):
        return self.pio.in_waiting
    def read(self, n):
        b = bytearray(n)
        n = self.pio.readinto(b)
        return b[:n]
    def readinto(self, buf):
        return self.pio.readinto(n)
class InvalidDataError(Exception):
    pass
class PM25:
    def __init__(self, data):
        if data[0:2] != b'BM':
            print('error decoding data:')
            print(data)
            raise InvalidDataError
        #print(data)
        self.pmStd1 = self.bytesConvert(data[4:6])
        self.pmStd25 = self.bytesConvert(data[6:8])
        self.pmStd10 = self.bytesConvert(data[8:10])
        self.pmEnv1= self.bytesConvert(data[10:12])
        self.pmEnv25 = self.bytesConvert(data[12:14])
        self.pmEnv10 = self.bytesConvert(data[14:16])
        self.part03u = self.bytesConvert(data[16:18])
        self.part05u = self.bytesConvert(data[18:20])
        self.part10u = self.bytesConvert(data[20:22])
        self.part25u = self.bytesConvert(data[22:24])
        self.part50u = self.bytesConvert(data[24:26])
        self.part100u = self.bytesConvert(data[26:28])
    def __str__(self):
        #eturn '<PM Std ug/m^3 1.0={0}, 2.5={1}, 10={2} atmos_env 1.0={3}, 2.5={4}, 10={5}>'.format(self.pmStd1, self.pmStd25, self.pmStd10, self.pmEnv1, self.pmEnv25, self.pmEnv10)
        return '<PM part count / 0.1L u0.3={0}, u0.5={1}, u1.0={2} u2.5={3}, u5.0={4}, u10={5}>'.format(self.part03u, self.part05u, self.part10u, self.part25u, self.part50u, self.part100u)
    @classmethod
    def bytesConvert(cls, data):
        return (int(data[0]) << 8) + int(data[1])
pm1 = RXUART(board.GP2)
pm2 = RXUART(board.GP4)
print('created uart %s' % pm1)
print('created uart %s' % pm2)
start = time.time()
while True:
    data1 = pm1.read(32)
    data2 = pm2.read(32)
    pmData1 = PM25(data1)
    pmData2 = PM25(data2)
    time_since = time.time() - start
    if time_since > 5:
        start = time.time()
        print(pmData1)
        print(pmData2)
adechiaro
