NeoPixel library for micropython?
by chipnod2020 on Fri Apr 09, 2021 8:53 am
I've been trying to find how to install the neopixel library for my Raspberry Pi Pico. From what I have been reading and finding, I am not sure if it exists.
My question: Is there a way to load neopixel libraries into the Pico, or since the processor is not compatible it doesn't exist yet?
chipnod2020
Re: NeoPixel library for micropython?
by dastels on Fri Apr 09, 2021 10:34 am
I don't know about support for MicroPython, but CircuitPython 6.2.0 runs on the Pico: https://circuitpython.org/board/raspberry_pi_pico/
dastels
by chipnod2020 on Fri Apr 09, 2021 10:51 am
Hey ya Dastels!
I have tried CircuitPython and the issue then becomes CP doesn't support interupts. For example, here is my micropython script.
import utime
from machine import Pin, PWM
### Pulse Cannons
# Pins
btn_pc = Pin(16, Pin.IN, Pin.PULL_UP) # GPIO 3 Physical pin 5
led_pc = Pin(17, Pin.OUT) # GPIO 4 Physical pin 6
# Variables
PC_blinkF = 100 # How long between flashes
PC_blinkT = 10 # How many flashes do you want times 2: 5 flashes = 10
def debounce(pin):
    prev = None
    for _ in range(32):
        current_value = pin.value()
        if prev != None and prev != current_value:
            return None
        prev = current_value
    return prev
def pc_callback(pin):
    d = debounce(pin)
    if d == None:
        return
    elif not d:
        for i in range(PC_blinkT):
            led_pc.toggle()
            utime.sleep_ms(PC_blinkF)
btn_pc.irq(trigger=Pin.IRQ_FALLING, handler=pc_callback)
so I don't think that circuitpython can support this, unless I'm a complete idiot.
chipnod2020
by dastels on Fri Apr 09, 2021 11:23 am
You're right, CircuitPython doesn't support interrupts (yet anyway). What does that have to do with NeoPixels?
dastels
by chipnod2020 on Fri Apr 09, 2021 11:28 am
Long story... The small example I posted here is a part of a larger code that will be combined to form one giant "robot" code piece. Ultimately I'm going to have a single piece of code running on a microcontroller to light up and control Star Trek ship models. The neopixel code that I am working on would simulate this via a button push.
https://www.youtube.com/watch?v=iefJuSzKwpI
So something I've always wanted to know about *python. If you define a function, does it interfere with other functions? what timer does not block code from running?
It's very possible I'm missing something very basic as I'm still learning.
chipnod2020
by dastels on Fri Apr 09, 2021 11:59 am
CircuitPython is, to my knowledge, single threaded.
dastels
by chipnod2020 on Mon Apr 12, 2021 4:32 pm
I looked up a few things that may make my life easier. Circuitpython does indeed support the neopixel better for the pico. I need to learn more on multasking within circuitpython. That will remediate the irq portion of my micropython code bits.
As always, thanks for your great advise!
chipnod2020
by dastels on Mon Apr 12, 2021 5:21 pm
dastels
