nrf52840 Feather with Motorwing
by tHoagland on Fri Apr 09, 2021 11:08 am
Good morning,
I've working with an nrf52840 feather and the Stepper+DC Motor Featherwing. The two are connected directly together via the pin-headers, the solder connections all look fine, and I checked continuity between all of the shared pins (3.3v, GND, SCL, SDA) and it seems OK. When I try to initialize the Motorkit object:
import board
from adafruit_motorkit import MotorKit
kit = MotorKit(i2c=board.I2C())
I get a runtime error:
RuntimeError: SDA or SCL needs a pull up
The 10K pullup resistor comes installed on the Motor wing and I measured resistance between the SDA/SCL and 3.3V and got 10k/8k respectively (which I think is fine). When I run that same motor wing on a different model feather (M4 express), everything works as expected.
This leaves me wondering if there might be some chipset specific configuration that I need for the nrf52840.
Any thoughts?
tHoagland
Re: nrf52840 Feather with Motorwing
by dastels on Fri Apr 09, 2021 11:16 am
The first step is to make sure you're using the lastest CircuitPython and libraries.
You don't need pullups with the Feather nRF52840. This issue pops up now & then.
dastels
by tHoagland on Fri Apr 09, 2021 11:32 am
Thanks Dave,
I am using the newest CircuitPython and Libraries. The pull up resistors on on the featherwing itself; do they need to be removed?
Any other suggestions?
tHoagland
by dastels on Fri Apr 09, 2021 11:57 am
Adafruit FeatherWings and breakouts have the required pullups on them. You don't have to worry about them.
The error can can be a result of poor SDA/SCL connections. Continuity between the header pins doesn't necessarily mean continuity between the two boards. I would redo the soldering on the relevant pins.
Post a clear photo of the soldering if you'd like comment.
dastels
