Trouble after CircuitPython install
by griffisp on Sun Apr 11, 2021 5:59 pm
I am having some trouble with my pyportal. I've searched and found someone had the same issue back in 2020 on GitHub and the issue was closed out. I've updated the boot loader and have downloaded and reloaded CircuitPython a couple of times. I keep getting the same error below.
code.py output:
Set background to /pyportal_startup.bmp
File "code.py", line 23, in <module>
File "adafruit_pyportal.py", line 214, in __init__
File "adafruit_pyportal.py", line 207, in __init__
File "adafruit_pyportal.py", line 386, in set_background
AttributeError: 'Display' object has no attribute 'refresh_soon'
Like many I'm new to these boards and MicroPython in general. I thought I could just try and edit the .py files but I can't seem to find them. I just see .mpy files.
Has anyone seen this issue? What am I doing wrong? Any idea where I can look to try and fix the issue?
Thanks for any help
Cheers,
Paul
griffisp
Re: Trouble after CircuitPython install
by dastels on Sun Apr 11, 2021 6:37 pm
It looks like you have outdated libraries. Upgrade everything to the latest. Delete everything in CIRCUITPY/lib and empty trash before copying over new libraries.
dastels
by griffisp on Sun Apr 11, 2021 8:17 pm
Thank you very much for the suggestion. I did what you said.
On the good hand, I'm no longer getting that error. On the other hand I'm getting a different error... lol.
code.py output:
File "adafruit_pyportal/__init__.py", line 152, in __init__
File "adafruit_pyportal/network.py", line 90, in __init__
File "adafruit_pyportal/wifi.py", line 77, in __init__
AttributeError: 'NoneType' object has no attribute 'is_connected'
Code done running.
I sort of understood what the first error was talking about. This error, no idea. Any thoughts?
Thanks again for any assistance.
Cheers,
Paul
griffisp
by tannewt on Sun Apr 11, 2021 8:44 pm
I think a fix is in the works. See viewtopic.php?f=60&t=177959
tannewt
by griffisp on Sun Apr 11, 2021 9:26 pm
Thanks very much for the link! It'll be nice when that gets fixed.
I'll try using an earlier version of that file as suggested in that thread.
Cheers,
Paul
griffisp
by aq7 on Mon Apr 12, 2021 12:48 am
Paul,
In 'BUG in pyportal/wifi.mpy', topic 177959, working code failed after upgrade.
A prior version of 'lib/adafruit_pyportal/wifi.mpy' got the code working.
Version dates were refined until the exact date of failure was found.
Dates before and after were reported to make it easy for another to find error.
Look at the last file listed in:
Drilling into Adafruit Circuit Python Library code:
github.com/adafruit <- start here
In the mid page search bar, 'Find a repository...', enter:
adafruit_pyportal
3 results found, select 'Adafruit_CircuitPython_PyPortal'
Now were looking at the PyPortal driver software. (Also Pynt & Titano)
Open folder adafruit_pyportal, which includes:
__init__.py
graphics.py
network.py
peripherals.py
wifi.py
Open wifi.py
Click on History, near upper right, and see:
Commits on April 11, 2021, 'fix testing esp.is_connected in init'
Commits on April 7, 2021, 'Assign requests if we have already connected'
Select 'Assign requests if we have already connected':
77 + if esp.is_connected:
78 + self.requests = requests
These two lines were added on April 7, and are exactly where the code failed:
Now look at 'fix testing esp.is_connected in init':
77 - if esp.is_connected:
77 + if self.esp.is_connected:
Line 77 was modified to correct bug.
You can download the file wifi.py onto your board into folder:
CIRCUITPY/lib/adafruit_pyportal
You do not need to delete wifi.mpy as wifi.py will take precedence:
docs.micropython.org/en/latest/reference/mpyfiles.html
As it is now a .py file, you can edit it.
Compiling .py files into .mpy save precious space on tiny file systems.
Hope this is helpful to you and others who come across this post.
Cheers!
aq7
