CircuitPython 6.2.0 LED Sequins
by jsnpnl on Tue Apr 13, 2021 10:55 am
I'm looking for a tutorial to code LED Sequins in the CircuitPython 6.2.0 software with the Circuit Playground Express
jsnpnl
Re: CircuitPython 6.2.0 LED Sequins
by dastels on Tue Apr 13, 2021 11:15 am
Unlike NeoPixels that require some programming to make them work, the LED sequins are simple LEDs. apply 3v-6v and they light up.
If you want to get fancy you can connect the + side to a PWM signal (and the - side to ground) to control the brightness. They are, however single color.
See https://learn.adafruit.com/adafruit-led-sequins. Although it's written for the Gemma M0, very similar code (maybe the outputs will need to be changed) will work on the CircuitPlayground Express.
dastels
