Funhouse setup for CIRCUIT PYHON
Re: Funhouse setup for CIRCUIT PYHON
by davidb21 on Wed Apr 21, 2021 2:32 pm
The good news is got the code to run by commenting out the dps310 stuff.
I love this board, keep up the good work.
davidb21
by davidb21 on Wed Apr 21, 2021 2:33 pm
I got the code to run by commenting out the dps310 libs. This is a great board.
davidb21
by davidb21 on Wed Apr 21, 2021 2:41 pm
I also plugged in the PIR sensor and it just worked. Really happy.
davidb21
by kwalkerk on Thu Apr 22, 2021 4:18 pm
I followed both sets of instructions, web enabled and esptool. Now it appears my funhouse is bricked, It doesn't show up as a drive nor does the serial port show up.
Any suggestions?
kwalkerk
by davidb21 on Sun Apr 25, 2021 8:35 am
If you are using a pi, run 'dmesg w'. Then turn the board off and back on. Do you see the board connecting, if not you may have a usc-c cable that is power only.
davidb21
by kwalkerk on Sun Apr 25, 2021 9:08 am
Thanks, but I Tried that -- nothing.
Doubt it's the cable. It's the same cable I used to try to put circuitpython on the board, which had no trouble until after the flash.
Also tried other known good usb cables, same result
kwalkerk
by davidb21 on Tue Apr 27, 2021 9:08 am
Curious. What OS are your using? Sometimes the port will become stale but a reboot of the computer we clear the hung process.
davidb21
by kwalkerk on Tue Apr 27, 2021 9:11 am
Using macOS Big Sur.
Have tried rebooting. Having even tried hooking up to linux(Ubuntu) machine, but it doesn't see it either. The only thing I get is the green power light on the board itself.
kwalkerk
by kwalkerk on Fri Apr 30, 2021 5:15 pm
Good news. Board was not bricked. I had to reload the tiny...bin. Once I did that I was able to upload the CircuitPython bin file using the web tool from Chrome.
Finally figured out that to see the usb port I had to hold down the BOOT Select button as the board was powered on and then the usb port showed up.
Thanks for your help!
kwalkerk
