Funhouse setup for CIRCUIT PYHON
by davidb21 on Mon Apr 19, 2021 1:50 pm
I was trying to setup the Funhouse board and must have done something wrong so I went followed the process used for the MagTag setup involving the running the following command on my rpi400:
sudo esptool.py -p /dev/ttyACM0 write_flash 0x0 magtag_tinyuf2_combo.bin
After doing this I now see the circuit python drive when plugging the board but I am having trouble running the default sketch from https://github.com/adafruit/Adafruit_Ci ... /tag/1.1.2 .
Do I need to use the esptool w/ another tinyuf2 so the the fun house board IO mappings are correct?
davidb21
Re: Funhouse setup for CIRCUIT PYHON
by davidb21 on Mon Apr 19, 2021 2:11 pm
Also, I am using MU as described in this post (https://learn.adafruit.com/welcome-to-c ... n?view=all) but cannot get the REPL working.
davidb21
by davidb21 on Mon Apr 19, 2021 2:37 pm
I think I bricked the funhouse board. I don't see the bin file located at https://github.com/adafruit/uf2-samdx1/ ... ag/v3.13.0, can it be posted?
davidb21
by DavidDyck on Mon Apr 19, 2021 11:53 pm
davidb21 wrote:Also, I am using MU as described in this post (https://learn.adafruit.com/welcome-to-c ... n?view=all) but cannot get the REPL working.
Hi davidb21, after receiving some advice on discord, I was able to get the bin file installed, and Mu editor to connect to the serial REPL !
DavidDyck
by DavidDyck on Mon Apr 19, 2021 11:56 pm
davidb21 wrote:I think I bricked the funhouse board. I don't see the bin file located at https://github.com/adafruit/uf2-samdx1/ ... ag/v3.13.0, can it be posted?
I was able to install the bin file from the S3 folder of https://circuitpython.org/board/adafruit_funhouse/
from discord I learned that I needed to do erase_flash command from esptool before the usual write_flash
DavidDyck
by davidb21 on Tue Apr 20, 2021 8:32 am
I was able to get the REPL as indicated above by running the erase and then flash using these commands:
sudo esptool.py -p /dev/ttyACM0 erase_flash
sudo esptool.py -p /dev/ttyACM0 write_flash 0x0 funhouse.bin
davidb21
by davidb21 on Tue Apr 20, 2021 9:01 am
Does the funhouse and magtag boards come from the factory w/ circuit python?
In order to get the REPL on these boards active I have had to use the esptool to flash them which I don't mind doing, but just wanted clarification if I am doing something wrong.
davidb21
by DavidDyck on Tue Apr 20, 2021 1:10 pm
davidb21 wrote:Does the funhouse and magtag boards come from the factory w/ circuit python?
The Funhouse did not come with circuit python installed. ( assuming it was an arduino sketch )
DavidDyck
by davidb21 on Tue Apr 20, 2021 3:11 pm
Is there a place I can download the modules to get the default example working, I am getting this:
File "code.py", line 7, in <module>
File "adafruit_dps310.py", line 34, in <module>
ImportError: no module named 'adafruit_register'
Thanks.
davidb21
by davidb21 on Tue Apr 20, 2021 3:12 pm
For reference, here is the code.py:
# SPDX-FileCopyrightText: 2017 Scott Shawcroft, written for Adafruit Industries
# SPDX-FileCopyrightText: Copyright (c) 2021 Melissa LeBlanc-Williams for Adafruit Industries
# SPDX-License-Identifier: Unlicense
import board
from digitalio import DigitalInOut, Direction, Pull
import adafruit_dps310
import adafruit_ahtx0
from adafruit_funhouse import FunHouse
funhouse = FunHouse(
default_bg=0x0F0F00,
scale=2,
i2c = board.I2C()
dps310 = adafruit_dps310.DPS310(i2c)
aht20 = adafruit_ahtx0.AHTx0(i2c)
funhouse.peripherals.set_dotstars(0x800000, 0x808000, 0x008000, 0x000080, 0x800080)
# sensor setup
sensors = []
for p in (board.A0, board.A1, board.A2):
sensor = DigitalInOut(p)
sensor.direction = Direction.INPUT
sensor.pull = Pull.DOWN
sensors.append(sensor)
def set_label_color(conditional, index, on_color):
if conditional:
funhouse.set_text_color(on_color, index)
else:
funhouse.set_text_color(0x606060, index)
# Create the labels
funhouse.display.show(None)
slider_label = funhouse.add_text(
text="Slider:", text_position=(50, 30), text_color=0x606060
capright_label = funhouse.add_text(
text="Touch", text_position=(85, 10), text_color=0x606060
pir_label = funhouse.add_text(text="PIR", text_position=(60, 10), text_color=0x606060)
capleft_label = funhouse.add_text(
text="Touch", text_position=(25, 10), text_color=0x606060
onoff_label = funhouse.add_text(text="OFF", text_position=(10, 25), text_color=0x606060)
up_label = funhouse.add_text(text="UP", text_position=(10, 10), text_color=0x606060)
sel_label = funhouse.add_text(text="SEL", text_position=(10, 60), text_color=0x606060)
down_label = funhouse.add_text(
text="DOWN", text_position=(10, 100), text_color=0x606060
jst1_label = funhouse.add_text(
text="SENSOR 1", text_position=(40, 80), text_color=0x606060
jst2_label = funhouse.add_text(
text="SENSOR 2", text_position=(40, 95), text_color=0x606060
jst3_label = funhouse.add_text(
text="SENSOR 3", text_position=(40, 110), text_color=0x606060
temp_label = funhouse.add_text(
text="Temp:", text_position=(50, 45), text_color=0xFF00FF
pres_label = funhouse.add_text(
text="Pres:", text_position=(50, 60), text_color=0xFF00FF
funhouse.display.show(funhouse.splash)
while True:
funhouse.set_text("Temp %0.1F" % dps310.temperature, temp_label)
funhouse.set_text("Pres %d" % dps310.pressure, pres_label)
print(aht20.temperature, aht20.relative_humidity)
set_label_color(funhouse.peripherals.captouch6, onoff_label, 0x00FF00)
set_label_color(funhouse.peripherals.captouch7, capleft_label, 0x00FF00)
set_label_color(funhouse.peripherals.captouch8, capright_label, 0x00FF00)
slider = funhouse.peripherals.slider
if slider is not None:
funhouse.peripherals.dotstars.brightness = slider
funhouse.set_text("Slider: %1.1f" % slider, slider_label)
set_label_color(slider is not None, slider_label, 0xFFFF00)
set_label_color(funhouse.peripherals.button_up, up_label, 0xFF0000)
set_label_color(funhouse.peripherals.button_sel, sel_label, 0xFFFF00)
set_label_color(funhouse.peripherals.button_down, down_label, 0x00FF00)
set_label_color(funhouse.peripherals.pir_sensor, pir_label, 0xFF0000)
set_label_color(sensors[0].value, jst1_label, 0xFFFFFF)
set_label_color(sensors[1].value, jst2_label, 0xFFFFFF)
set_label_color(sensors[2].value, jst3_label, 0xFFFFFF)
davidb21
by davidb21 on Tue Apr 20, 2021 5:22 pm
I found the libs located here: https://circuitpython.org/libraries
I've been trying to install them one at a time but just keep find more modules I need to install.
Is there a FunHouse git repo that has all the library files needed to run example code?
davidb21
by davidb21 on Tue Apr 20, 2021 5:48 pm
I think I found the require libs:
Adafruit-Blinka
adafruit-blinka-displayio
adafruit-circuitpython-portalbase
adafruit-circuitpython-dotstar
adafruit-circuitpython-requests
adafruit-circuitpython-simpleio
adafruit-circuitpython-minimqtt
Need a download link.
davidb21
by davidb21 on Tue Apr 20, 2021 6:35 pm
So I found the blinka source code, but will this work if I just drop it on the funhouse lib directory or does it need to live on the same directory as the code.py / main.py?
https://github.com/adafruit/Adafruit_Bl ... er/esp8266
davidb21
by davidb21 on Wed Apr 21, 2021 8:16 am
Also, is the demo *.ino code to load into Arduino available?
davidb21
by davidb21 on Wed Apr 21, 2021 2:27 pm
I am following the new FunHouse guide published today, but I get the following error:
Code done running.
davidb21
