Hi, I'm using Adafruit FT232H Breakout as a GPIO input for Windows10 PC.
Code to detect input is written in python3 and works nicely.
However, input signal tends to stay 'HIGH (True)' these days.
Is it possible to detect RISING of input signal and to set bounce time like ' RPi.GPIO' ?
e.x. GPIO.add_event_detect(24, GPIO.RISING, bouncetime=1000)
Thank you in advance !
FT232H GPIO rising
- tannewt
Re: FT232H GPIO rising
What code are you currently using?
- yhar
Hi, tannewt !
thank you for your responce.
my code regarding input is as follows;
import board
import digitalio
button = digitalio.DigitalInOut(board.C0)
button.direction = digitalio.Direction.INPUT
if button.value == True:
** do something **
hope you can tell from above.
if there are pages for this issue, pls kindly let me know.
thank you.
import board
import digitalio
** do something **
thank you.
- yhar
Hi there !
still struggling. any info regarding detect rising ?
thanx
yhar
thanx
yhar
- tannewt
The simplest thing would be to store the last state of the pin in a variable. Then you can do whatever you want when the last is False but the current state is True.
- yhar
Hi tannewt,
thank you for your suggestion.
i think i can make it.
