FeaterS2 & LTR390 not working
by kurthofman on Mon Apr 26, 2021 9:35 am
When I try to run the test-code for the LTR390 module on a Feater S2 I get an error.
Module seems to connect in Arduino but I get no UV index.
Board : Feater S2
Module : ADAFRUIT LTR390 UV LIGHT SENSOR - STEMMA QT / QWIIC (4831)
Code :
import time
import board
import adafruit_ltr390
i2c = board.I2C()
ltr = adafruit_ltr390.LTR390(i2c)
while True:
print("UV:", ltr.uvs, "\t\tAmbient Light:", ltr.light)
print("UVI:", ltr.uvi, "\t\tLux:", ltr.lux)
time.sleep(1.0)
Error :
code.py output:
File "code.py", line 6, in
File "adafruit_ltr390.py", line 254, in init
File "adafruit_ltr390.py", line 260, in initialize
File "adafruit_ltr390.py", line 283, in _reset
File "adafruit_register/i2c_bit.py", line 43, in get
OSError: [Errno 5] Input/output error
Code done running.
Last edited by adafruit_support_carter on Wed Apr 28, 2021 9:46 am, edited 1 time in total.
Reason: added [code] tags
kurthofman
Re: FeaterS2 & LTR390 not working
by kurthofman on Mon Apr 26, 2021 11:31 am
Module works in Arduino with Huzzah esp32.
kurthofman
by adafruit_support_carter on Mon Apr 26, 2021 11:49 am
How are you connecting the LTR390 to the Feather S2?
by kurthofman on Tue Apr 27, 2021 2:58 am
The LTR390 is connected to the Feather S2 over STEMMA, same as if I connect it to the Huzzah32 for the Arduino-test.
kurthofman
by adafruit_support_carter on Tue Apr 27, 2021 10:44 am
Hmm. That should be fine. Seems like a connection issue though. Can you post a photo of your setup showing how everything is connected.
by kurthofman on Wed Apr 28, 2021 6:12 am
This is my setup, I used the same Stemma-cable to connect to the Huzzah32
IMG_0340 (Aangepast).JPG (148.57 KiB) Viewed 42 times
kurthofman
by kurthofman on Wed Apr 28, 2021 7:15 am
Test on the Feather S2 :
import board
import busio
i2c = busio.I2C(board.SCL, board.SDA)
while not i2c.try_lock():
    pass
devices = i2c.scan()
while len(devices) < 1:
device = devices[0]
print('Found device with address: {}'.format(hex(device)))
result = bytearray(2)
i2c.writeto(device, bytes(6))
i2c.readfrom_into(device, result)
print('Address {0}: {1}'.format(hex(6), ' '.join([hex(x) for x in result])))
i2c.unlock()
This gives me, what I think is OK :
code.py output:
Found device with address: 0x53
Address 0x6: 0x1 0xb2
Last edited by adafruit_support_carter on Wed Apr 28, 2021 9:44 am, edited 1 time in total.
kurthofman
by kurthofman on Wed Apr 28, 2021 7:35 am
If I make the following change in adafruit_ltr390 (disable _reset") it seems to work.
class LTR390:
def _reset(self):
try:
self._reset_bit = True
except OSError:
# The write to the reset bit will fail because it seems to not ACK before it resets
pass
sleep(0.1)
# check that reset is complete w/ the bit unset
if self._reset_bit:
raise RuntimeError("Unable to reset sensor")
kurthofman
by adafruit_support_carter on Wed Apr 28, 2021 10:12 am
Thanks. I've recreated the original problem and opened an issue for this here:
https://github.com/adafruit/Adafruit_Ci ... 0/issues/6
Seems like something specific to the ESP32-S2.
