feather s2 and mlx90614 3v wiring question
by jfranklyn on Wed Apr 28, 2021 2:04 pm
Hello all,
I'm working on the wiring for a featherS2 and an MLX90614 3V sensor. Can I use the 3V output pin on the featherS2 to wire the resistors to the SDA, SCL pins? I have it wired like this now and I'm getting an error that SDA, SCL need a pullup. Do I need to wire the resistors to the main 3V pin?
jfranklyn
Re: feather s2 and mlx90614 3v wiring question
by blnkjns on Wed Apr 28, 2021 4:56 pm
Usually you can toggle pull-up resistors on ports in software:
pinMode(pinNumber,INPUT_PULLUP);
Oops, this was CircuitPython teritory.
A bit more lines are needed:
https://learn.adafruit.com/circuitpytho ... tal-in-out
blnkjns
by jfranklyn on Thu Apr 29, 2021 1:33 pm
thanks for this but I'm not using the GPIO pins. I'm only using 3V, GND, SDA, SCL. I need to know if I can use the 3v output pin 3VO as the source for the 2 pull up resistors that need to be connected to the SDA, SCL pins.
jfranklyn
by franklin97355 on Thu Apr 29, 2021 1:53 pm
I don't see why you couldn't but I'll check. Have you checked if the 3v power supply works?
franklin97355
by adafruit2 on Thu Apr 29, 2021 3:34 pm
you should be able to but we dont use the feather s2 so much - we really recommend posting in their support forums/discord because there may be some detail we dont know about :D
adafruit2
Site Admin
by jfranklyn on Fri Apr 30, 2021 3:21 pm
Hello all,
For the feathers2 you can't use the 3VO pin as the pull-up voltage for the resistors on the mlx90614 3V sensor. I switches the resistors to the main 3V pin and the sensors works as expected. It would be nice to know what the difference is between the 3V and 3VO pins.
jfranklyn
by adafruit2 on Fri Apr 30, 2021 3:27 pm
hihi, we dont manufacture the s2, so we aren't the definitive source of hardware info (and we dont want to say something wrong) - please ask the maker on their forums, they're very responsive!
adafruit2
Site Admin
