M4 CAN Express weird problem
valtsu23
Post by valtsu23 »
Hi!
I'm trying to build a small Can Bus gauge to my car. I have Feather M4 Can express connected to 2.4" TFT FeatherWing. Screen is working fine, but I don't get Can Bus communication to work.
My car has aftermarket ECU (Ecumaster emu Black). It supports CAN BUS 2.0A and 2.0B. Default ECU ID HEX 600.
Default can stream info: https://filedn.com/lKOo3aQn9ubHtKC7DXLE ... tream.html
From ECU software I have set CAN bus speed to 500 kbps, enabled CAN bus stream and enabled 120ohm termination resistor.
I have checked that termination resistor is ok on Feather with multimeter.
On serial I see line: "Bus state changed to canio.BusState.ERROR_ACTIVE" and after that all the time I'm getting "no message received within timeout".
I have tried changing number of things. I even tried without any kind of message filtering and still nothing. If I try sending message with the loopback it works fine.
Can bus is wired from ECU to OBD port and from there to Feather. I tried plugging in OBD reader and it connected fine and showed sensor data from ECU as it should.
I borrowed Fluke Scopemeter from work and used it to log bus voltages. Ch A is Can High and Ch B is Can low. Ground reference is connected.
Here is video with Feather connected, but NOT powered on: https://youtu.be/eRN3P92qMd0
Looks as it should. Can high voltage changes between 2,5v and 3,5v. Can low voltage changes between 2,5v and 1,5v.
Here is video with Feather connected and power ON: https://youtu.be/PKZ2HQVNnPM
Signal looks strange. Can high voltage changes between 2v and 3,8v. Can low voltage changes between 2,5v and 1,5v.
I tried the silent parameter setting on canio.CAN, but still same problem.
Any ideas what is wrong? I'm starting to believe the transceiver is faulty.
Here is the code I have tried:
import struct
import time
import board
import canio
import digitalio
# If the CAN transceiver has a standby pin, bring it out of standby mode
if hasattr(board, 'CAN_STANDBY'):
    standby = digitalio.DigitalInOut(board.CAN_STANDBY)
    standby.switch_to_output(False)
# If the CAN transceiver is powered by a boost converter, turn on its supply
if hasattr(board, 'BOOST_ENABLE'):
    boost_enable = digitalio.DigitalInOut(board.BOOST_ENABLE)
    boost_enable.switch_to_output(False)
# Use this line if your board has dedicated CAN pins. (Feather M4 CAN and Feather STM32F405)
#can = canio.CAN(rx=board.CAN_RX, tx=board.CAN_TX, baudrate=500_000, auto_restart=True, loopback=True)
can = canio.CAN(rx=board.CAN_RX, tx=board.CAN_TX, baudrate=500_000, auto_restart=True)
# On ESP32S2 most pins can be used for CAN.  Uncomment the following line to use IO5 and IO6
#can = canio.CAN(rx=board.IO6, tx=board.IO5, baudrate=250_000, auto_restart=True)
listener = can.listen(matches=[canio.Match(602, mask=604)], timeout=.9)
#listener = can.listen(matches=[canio.Match(603)], timeout=.9)
old_bus_state = None
count = 5
count2 = 10
while True:
    bus_state = can.state
    if bus_state != old_bus_state:
        print(f"Bus state changed to {bus_state}")
        old_bus_state = bus_state
    now_ms = (time.monotonic_ns() // 1_000_000) & 0xffffffff
#    print(f"Sending message: count={count}")
#    message = canio.Message(id=602, data=struct.pack("<II", count, now_ms))
#    can.send(message)
#    message2 = canio.Message(id=603, data=struct.pack("<II", count2, now_ms))
#    can.send(message2)
    message = listener.receive()
    data = message.data
    ID = message.id
    if len(data) != 8:
        print(f"Unusual message length {len(data)}")
        continue
    if message is None:
        print("No message received within timeout")
        continue
    if ID == 602:
        count, now_ms = struct.unpack("<II", data)
        print(f"received message: count={count} now_ms={now_ms}")
        time.sleep(1)
    if ID == 603:
        time.sleep(1)
valtsu23
Re: M4 CAN Express weird problem
Post by valtsu23 »
Seems like can bus voltages compared to ground don't make much sense when Feather is powered on.
When I logged just the voltage level between CAN High and CAN low they seem to be fine when Feather is on:
So maybe the transceiver is ok. I ordered MCP2515 to try with Arduino, so I can do some testing with it.
I will update when I have some results.
valtsu23
Post by valtsu23 »
valtsu23 wrote:Seems like can bus voltages compared to ground don't make much sense when Feather is powered on.
Here is the image. Link is broken somehow :|
valtsu23
Post by valtsu23 »
I received the MCP2515 today and did some testing using this library: https://github.com/timurrrr/arduino-CAN
After few attemps I got communication to work both ways.
Notes:
-with MCP2515 set to 500kbps the Feather needs 250_000 baud rate.
-Feather won't send or receive any messages if boost converter is not enabled with usb power supply.
I don't understand why baud rate and kbps won't match in this case.
Seems like the transceiver is only powered thru boost converter. This isn't clearly told on any guide or example.
valtsu23
Post by valtsu23 »
I tested with the car Ecu and seems like only problem was the boost converter, which wasn't enabled.
Baud rate of 500_000 worked fine.
