Trellis M4 hid error : Launch Deck Trellis M4
by davidb21 on Tue May 04, 2021 12:08 pm
I am trying to get some hid examples (see below) working but keep hitting library errors.
Can some point me towards a bundle for the Launch Deck Trellis M4 that has hid working.
# Launch Deck Trellis M4
# USB HID button box for launching applications, media control, camera switching and more
# Use it with your favorite keyboard controlled launcher, such as Quicksilver and AutoHotkey
import adafruit_trellism4
import time
import random
from adafruit_hid.keyboard import Keyboard
from adafruit_hid.keycode import Keycode
from adafruit_hid.consumer_control import ConsumerControl
from adafruit_hid.consumer_control_code import ConsumerControlCode
== snip ==
Line 84: kbd = Keyboard()
code.py output:
File "code.py", line 84, in <module>
TypeError: function takes 2 positional arguments but 1 were given
davidb21
Re: Trellis M4 hid error : Launch Deck Trellis M4
by kattni on Tue May 04, 2021 2:24 pm
It's not the bundle that is the issue, it is the code. I don't have an exact updated version of the code you're using, but here is a snippet of the setup from a working example.
import usb_hid
from adafruit_hid.keyboard_layout_us import KeyboardLayoutUS
keyboard = Keyboard(usb_hid.devices)
keyboard_layout = KeyboardLayoutUS(keyboard)
You need to import usb_hid, and provide usb_hid.devices to the Keyboard() object.
kattni
by davidb21 on Tue May 04, 2021 2:47 pm
I found out I was using a old version of the hid library. It now works but now am having with the Mac keyboard mappings.
I have the 0,0 pushbutton working which brings up the Mac screen capture.
I can't get the Mac 'F3' button (code config below) to work which makes all the windows be visible.
Any ideas.
keymap = {
(0,0): (0x001100, KEY, (Keycode.COMMAND, Keycode.SHIFT, Keycode.FIVE)),
#(0,0): (0x001100, MEDIA, ConsumerControlCode.PLAY_PAUSE),
(1,0): (0x110011, KEY, (Keycode.F3)),
davidb21
by kattni on Tue May 04, 2021 2:55 pm
I'm not sure. Is it possibly related to Macs often needing the function key to be pressed to access the Fx keys? Or that you're utilising a Mac shortcut that isn't directly assigned to F3, but instead to the alternate keymapping of that key?
Beyond that, I'm uncertain. I would recommend creating a new forum post if you can't sort it out so that your new question doesn't get lost in this topic.
kattni
by davidb21 on Tue May 04, 2021 5:01 pm
I found a work around. I am using (1,0): (0x110011, KEY, (Keycode.CONTROL, Keycode.UP_ARROW)). Thanks!
davidb21
by davidb21 on Tue May 11, 2021 7:34 am
I purchased another Trellis M4 kit and downloaded the bundle for the 8 step learn example.
It did not work and there was an error with the neopixle library. I did a md5sum on the neopixle library from the bundle example for the learn application launcher library and saw a different hash.
I placed the neopixle library from the application launch bundle and that fixed the problem.
So it seems like the learn example bundle for the 8 step has an issue.
davidb21
