Mu Editor Problem with MacBook Air M1
- RocketScientist
I am having a problem running Mu Editor w/ Adafruit CircuitPython w/ MacBook Air M1. I can edit programs, but cannot connect to the serial REPL. When running with my old x86 MacBook Pro - same version of MacOS - all works fine. FWIW ... running MacOS 11.3 on both machines. It does seem to want to run on Python 3.8 despite upgrading MacOS Python to 3.9.5.
- RocketScientist
Re: Mu Editor Problem with MacBook Air M1
Curiously ... it does seem to work on the M1 under Parallels in a VM using Windows 10 for ARM and Mu Editor.
- danhalbert
Which version of Mu are you using? Are you using one of the new betas? You might want to report this at https://github.com/mu-editor/mu/issues as well, especially because of the M1 issue.
- RocketScientist
Using the latest version. Have reported it there. Rather confusing support platform methinks.
I’m convinced it’s a Mu issue with some subtlety of the M1. The fact it works on Win10 ARM under a VM on the M1 seems absolutely diagnostic.
Also kinda cool.
Also kinda cool.
- danhalbert
We have confirmed that the board detection is not working on M1 MacOS, but is working on non-M1 MacOS (same latest version), where is was developed. Now we need to figure out why.
- RocketScientist
Yay! I trust it will all get resolved. In short term I can use my convoluted workaround.
- danhalbert
We filed a PR to mu to fix this and it has been accepted and should be in Mu 1.1.0-beta.5. In the meantime you can delete the build artifact for the PR and try it out:
PR: https://github.com/mu-editor/mu/pull/1580
MacOS build: https://github.com/mu-editor/mu/suites/ ... s/61703887
