PWM optimised for analogue output
kevinjwalters
Post by kevinjwalters »
Has anyone looked into optimising PWM for use as an analogue output? I was thinking about reducing ripple by distributing the high periods of the duty cycle, i.e. if resolution is 1/8ths of a cycle and output is 25% duty cycle (16384 in CircuitPython's range), this
becomes
I realise this could be done to some extent with variable_frequency but it would be easier if it was done under the covers particularly if the hardware has features to support this efficiently.
Re: PWM optimised for analogue output
If I understand correctly, what you are describing is equivalent to simply doubling the PWM frequency. The duty-cycle remains the same. The pulses are just half as long.
kevinjwalters
In that case, but for pwm.duty_cycle = 24576 I'd expect something like
It could be branded as PDM.
BTW, I intended to put this in the Adafruit CircuitPython and MicroPython forum, if you could move it over there that would be great.
[topic moved]
I don't know of any processors that would have direct hardware support for that. You could implement it in software. Or perhaps even using some DMA magic on processors that support it. But I don't think it would buy you any improvement over just increasing the base frequency and using straight hardware PWM.
