Factory Installed blink.uf2
blakebr
Post by blakebr »
Where can I find the factory installed *.uf2 test files for the:
QT Py RP2040
ItsyBitsy RP2040
Feather RP2040 boards. The files that randomly flash the NeoPixel when the board comes from the factory.
The source code would be appreciated for learning purposes. I do not have a C++ compiler other than the Arduino one.
Thank you,
Bruce
kattni
Re: Factory Installed blink.uf2
Post by kattni »
Hello.
The Feather UF2 was already in the guide on the Downloads page.
https://learn.adafruit.com/adafruit-fea ... /downloads
I added the ItsyBitsy and QT Py UF2s to their respective Downloads pages.
https://learn.adafruit.com/adafruit-its ... /downloads
https://learn.adafruit.com/adafruit-qt- ... /downloads
~ Kattni
blakebr
Post by blakebr »
Katnni,
I must admit I didn't look on the Feather page, so I am at fault for not RTFM.
Thank you for adding the files to QT Py and ItsyBitsy.
Thank you again for for your help again.
Bruce
blakebr
Post by blakebr »
Mike,
Sorry, but Kattni beat you to the punch.
Go Kattni! ;-)
Thanks to both of you for your help,
Bruce
blakebr
Post by blakebr »
Is there a way I can get a copy of the source code to the factory installed blink routines.
I assume that same code is used for each RP2040 device with their respective version of CircuitPython adjusting for pin usage.
Thanks for your help,
Bruce
tannewt
Post by tannewt »
I don't think the blink examples are done with CircuitPython. Sorry!
blakebr
Post by blakebr »
tannewt,
A copy of the C++ code would work too. I want to see what is done and and learn from it.
I assume it is the same code is compiled under the board version it will be run on.
Bruce
