I'm trying to use a feathers2 with a DS18B20 sensor. I'm using the code from ds18x20_simpletest.py
This line of code keeps failing with number of devices exceeded:
ds18 = DS18X20(ow_bus, ow_bus.scan()[0])
I have a print-out of the feathers2 board. I "think" I have the data (yellow) wire plugged into pin D19. I don't know if this is D19, D10 or D5. The pin number on the board is 5. I'm running the latest firmware on the feathers2: adafruit-circuitpython-unexpectedmaker_feathers2-en_US-6.2.0
I've included a screen capture of the board wiring.
Any help would be greatly appreciated.
feathers2 pin number confusion
- jfranklyn
- 20210511_112207.jpg (726.91 KiB) Viewed 144 times
- jfranklyn
Re: feathers2 pin number confusion
Follow up on this problem. This code is from: ds18x20_asynctest.py
import board
from adafruit_onewire.bus import OneWireBus
from adafruit_ds18x20 import DS18X20
ow_bus = OneWireBus(board.D19)
ow_bus.scan()
Based on the result above, I expect this next code to fail with index out of range. I think this tells me that I have the correct pin number (D19), BUT something else is wrong.
File "<stdin>", line 1, in <module>
IndexError: list index out of range
import board
ow_bus.scan()
- kevinjwalters
Looks like D19 according to pinout on https://unexpectedmaker.com/shop/feathers2-esp32-s2
The solder joint on GND looks a bit iffy, might be worth resoldering in case you have a high resistance dry-joint there.
