I'm having an issue with a simple While loop and I don't understand why. I have two triggers to start my sequence ("pe" a Pull.UP input and "fob" a Pull.DOWN input). Either one will work on its own, but when I try using an OR neither work. I'm still very much a novice and have a lot to learn, but I've used multiple AND and OR conditions in While loops before without any issue. I'm not sure what the difference is.
Any help would be greatly appreciated.
My issue is about halfway down and starts at the "# Start signal" comment. while pe.value: and while not fob.value work, but combining them like while pe.value or not fob.value: doesn't work.
import time
import board
import neopixel
import digitalio
import pulseio
import pwmio
from audiocore import WaveFile
from adafruit_motor import servo
from audiomp3 import MP3Decoder
from digitalio import DigitalInOut, Direction, Pull
try:
import urandom as random
except ImportError:
import random
try:
from audioio import AudioOut
except ImportError:
try:
from audiopwmio import PWMAudioOut as AudioOut
except ImportError:
pass # not always supported by every board!
#IO
pe = digitalio.DigitalInOut(board.D11) # Photo Eye to Start
pe.direction = Direction.INPUT
pe.pull = Pull.UP
fob = digitalio.DigitalInOut(board.D6) # Remote Control to Start
fob.direction = Direction.INPUT
fob.pull = Pull.DOWN
pwm = pulseio.PWMOut(board.D4, duty_cycle= 2 ** 15, frequency=50) # Configures pin A3 to be PWM
my_servo = servo.Servo(pwm) # Configures "pwm" to be a servo, my_servo
vib1 = pulseio.PWMOut(board.D12, duty_cycle=0, frequency=5000) # Configures pin D12 to be PWM
#NeoPixels
numpix = 32 # Number of NeoPixels
pixpin = board.D5 # Pin where NeoPixels are connected
pixels = neopixel.NeoPixel(pixpin, numpix, brightness=0.0)
red = (255, 0, 0)
off = (0, 0, 0)
colors = [
[255, 40, 0],
[255, 30, 0],
[255, 10, 0],
[255, 0, 0],
embedded_led = neopixel.NeoPixel(board.NEOPIXEL, 1, brightness=0.0) # Embedded NeoPixel in the Feather
embedded_led[0] = (red)
# Audio
mp3files = ["fire1.mp3", "fire2.mp3"]
# You have to specify some mp3 file when creating the decoder
mp3 = open(mp3files[0], "rb")
decoder = MP3Decoder(mp3)
audio = AudioOut(board.A0)
# Main loop
while True:
for filename in mp3files:
decoder.file = open(filename, "rb")
audio.play(decoder) # Starts playing the audio file
print("playing", filename)
# This allows you to do other things while the audio plays!
t = time.monotonic()
while time.monotonic() - t < 0: # "0" prohibits playing at startup
pass
audio.pause() # Audio file is puased instantly
print("Waiting for trigger")
while pe.value: # Start signal
pass
# while not fob.value:
# pass
# while pe.value or not fob.value:
# pass
# while not fob.value or pe.value:
# pass
for angle in range (0, 80, 1): # Moves servo from 0° to 80° one degree at a time
my_servo.angle = angle # Counts by 1 and moves to position
time.sleep(.05) # Speed (0.05 works well)
print(angle) # Angle Readout
audio.resume() # Audio file resumes playing
vib1.duty_cycle = 30000 # Vibration motor starts
pixels.fill(red) # Turns all the neopixels red
for x in range(33): # The higher the range the longer the cycle
rest = [0.01, 0.02, 0.03, 0.04, 0.05, 0.06,
0.07, 0.08, 0.09] # Used for the random flicker
c = random.randint(0, len(colors) - 2) # Choose random color index
pixelnum = random.randint(0, numpix - 2) # Choose random pixel
pixels[pixelnum] = colors[c] # Set pixel to color
for i in range(1, 5):
pixels.brightness = i / 5.0 # Ramp up brightness
pixels.write()
time.sleep(random.choice(rest)) # Random flicker
for i in range(5, 1, -1):
pixels.brightness = i/ 2 / 5.0 # Ramp down brightness
pixels.write()
pixels.fill(off) # Turns off all the neopixels
vib1.duty_cycle = 0 # Vibration motor stops
while audio.playing:
pass
for angle in range (80, 0, -1): # Moves servo from 80° to 0° negative one degree at a time
Feather M4 Express PID: 3857
Adalogger FeatherWing RTC + SD PID: 2922
Simple RF M4 Receiver - 315MHz Momentary Type PID: 1096
Sharp GP2Y0D805Z0F PID: 3025
