Broke my old code after update, any idea what I missed?
Re: Broke my old code after update, any idea what I missed?
by burrito_poots on Thu Jun 03, 2021 2:32 pm
Foamyguy wrote:In this section of code starting around line 90:
if current_program != "Fil" and buttond_was_pushed:
        # We are on main screen or CIP, but want Fil.
        # Go there
        text_area4 = label.Label(terminalio.FONT, text="Mode:", scale=1, color=0xFFFFFF, x=0, y=5)
        fillscreen.append(text_area4)
All of these text_areas 4 through 12 should be created and appended to the fillscreen Group sometime before the main loop (the while True: loop).
Then inside the main loop here there should be calls like text_area4.text = "Mode:" whenever you need to set or change the text that is showing.
I'll try this! I'm not entirely sure what's going on, but with zero changes, but code started working without the ghosting issues last night for a few mins after another reset, then started ghosting again — any idea why that would happen? My guess is it's outside of the code (memory issue, maybe a board issue, etc.) but I'm honestly not sure about anything here.
Code as of this last one:
import board
import displayio
import terminalio
import busio
import digitalio
import adafruit_displayio_sh1107
from adafruit_display_text import label
displayio.release_displays()
# old_reset = board.D9
# Use for I2C
i2c = board.I2C()
display_bus = displayio.I2CDisplay(i2c, device_address=0x3C)
# SH1107 is vertically oriented 64x128
WIDTH = 128
HEIGHT = 64
BORDER = 2
display = adafruit_displayio_sh1107.SH1107(display_bus, width=WIDTH, height=HEIGHT)
color_bitmap = displayio.Bitmap(WIDTH, HEIGHT, 1)
color_palette = displayio.Palette(1)
color_palette[0] = 0xFFFFFF # White
# Make the display context
splash = displayio.Group()
display.show(splash)
fillscreen = displayio.Group()
CIPscreen = displayio.Group()
fillscreenActive = displayio.Group()
import rotaryio
import time
from adafruit_motorkit import MotorKit
import adafruit_vl6180x
# from adafruit_debouncer import Debouncer
sensor = adafruit_vl6180x.VL6180X(i2c)
encoderB = rotaryio.IncrementalEncoder(board.D12, board.D11)
button_e = digitalio.DigitalInOut(board.D10)
button_e.direction = digitalio.Direction.INPUT
button_e.pull = digitalio.Pull.UP
encoderA = rotaryio.IncrementalEncoder(board.A4, board.A3)
button_d = digitalio.DigitalInOut(board.A2)
button_d.direction = digitalio.Direction.INPUT
button_d.pull = digitalio.Pull.UP
range_mm = sensor.range
kit = MotorKit()
buttond_was_pushed = False
buttone_was_pushed = False
current_program = "Monarch"
program_running = False
lastA_position = None
lastB_position = None
# turn off auto refresh
#display.auto_refresh = False
text_area = label.Label(terminalio.FONT, text="monarch", scale=3, color=0xFFFFFF, x=3, y=12)
splash.append(text_area)
text_area2 = label.Label(terminalio.FONT, text="FLUID SYSTEMS", scale=1, color=0xFFFFFF, x=28, y=36)
splash.append(text_area2)
text_area3 = label.Label(terminalio.FONT, text="nano MK.I", scale=1, color=0xFFFFFF, x=70, y=55)
splash.append(text_area3)
#display.refresh()
while True:
    if button_d.value == 0:
        # Button_d has been pressed
        buttond_was_pushed = True
    if button_e.value == 0:
        # Button_e has been pressed
        buttone_was_pushed = True
    #if current_program == "Monarch" and buttond_was_pushed:
        # Go there
        text_area5 = label.Label(terminalio.FONT, text="{ OFF", scale=1, color=0xFFFFFF, x=0, y=15)
        fillscreen.append(text_area5)
        text_area6 = label.Label(terminalio.FONT, text="  ON", scale=1, color=0xFFFFFF, x=0, y=25)
        fillscreen.append(text_area6)
        text_area7 = label.Label(terminalio.FONT, text=" Time:", scale=1, color=0xFFFFFF, x=36, y=5)
        fillscreen.append(text_area7)
        text_area8 = label.Label(terminalio.FONT, text="0.0", scale=1, color=0xFFFFFF, x=102, y=5)
        fillscreen.append(text_area8)
        text_area9 = label.Label(terminalio.FONT, text=" Foam Pulse:", scale=1, color=0xFFFFFF, x=36, y=25)
        fillscreen.append(text_area9)
        text_area10 = label.Label(terminalio.FONT, text="0", scale=1, color=0xFFFFFF, x=116, y=25)
        fillscreen.append(text_area10)
        text_area11 = label.Label(terminalio.FONT, text="º", scale=1, color=0xFFFFFF, x=32, y=5)
        fillscreen.append(text_area11)
        text_area12 = label.Label(terminalio.FONT, text="º", scale=1, color=0xFFFFFF, x=32, y=13)
        fillscreen.append(text_area12)
        text_area13 = label.Label(terminalio.FONT, text="º", scale=1, color=0xFFFFFF, x=32, y=21)
        fillscreen.append(text_area13)
        text_area14 = label.Label(terminalio.FONT, text="º", scale=1, color=0xFFFFFF, x=32, y=29)
        fillscreen.append(text_area14)
        display.show(fillscreen)
        current_program = "Fil"
    if current_program == "Fil" and buttond_was_pushed and not program_running:
        # Button was pushed, but program not yet running.
        # Make it run!
        program_running = True
    try:
        print('Range: {0}mm'.format(range_mm))
    except RuntimeError:
        print("retrying!")
    # time.sleep(.00001)
    if current_program == "Fil" and not buttond_was_pushed and program_running:
        # Fill program running, but button is not pushed... now what?
        positionA = encoderA.position
        if lastA_position is None or positionA != lastA_position:
            print(positionA)
        lastA_position = positionA
        timingA_value = 0.1*encoderA.position
        print(timingA_value)  # can remove this once verified it works
        text_area5.text = "  OFF"
        text_area6.text = "{ ON "
        text_area8.text = str(timingA_value)
        #display.show(fillscreen)
        positionB = encoderB.position
        if lastB_position is None or positionB != lastB_position:
            print(positionB)
        lastB_position = positionB
        timingB_value = encoderB.position
        print(timingB_value)  # can remove this once verified it works
        text_area10.text = str(timingB_value)
        if (range_mm >= 70):
            kit.motor2.throttle = 1.0       # Load first can
            time.sleep(.8)                  # Piston extension time
            kit.motor2.throttle = 0         # Piston retract
            time.sleep(1)                   # need for can to fall into chute
            kit.motor2.throttle = 1.0       # Load Second can
            time.sleep(1)                   # prevents lift hitting moving cans
            kit.motor4.throttle = 1.0       # Drop lift piston
            kit.motor1.throttle = 1.0       # Start Purge
            time.sleep(1.5)                 # Hold for 1.5 s
            kit.motor1.throttle = 0         # Stop Purge
            kit.motor3.throttle = 1.0       # Start Fill
            time.sleep(timingA_value)       # Hold for set time
            kit.motor3.throttle = 0         # End fill
            for _ in range(timingB_value):
                time.sleep(0.05)                # Hold for set time
                kit.motor3.throttle = 1.0       # Start Foam Pulse
                kit.motor3.throttle = 0         # End Foam Pulse
            kit.motor4.throttle = 0             # Raise lift
            time.sleep(.75)
    try:
        print('Range2: {0}mm'.format(range_mm))
        print("retrying!")
    if current_program != "CIP" and buttone_was_pushed:
        # We are on Monarch, and want CIP.
        # Go there
        display.fill(0)
        display.text('Mode:', 0, 0, 1)
        # display.text('{ OFF', 0, 10, 1)
        display.text('  CIP', 0, 20, 1)
        display.text(' Valves Closed', 36, 20, 1)
        display.text('º', 32, 0, 1)
        display.text('º', 32, 8, 1)
        display.text('º', 32, 16, 1)
        display.text('º', 32, 24, 1)
        kit.motor4.throttle = 0.0
        kit.motor3.throttle = 0.0
        current_program = "CIP"
    if current_program == "CIP" and buttone_was_pushed and not program_running:
        # Make it run!
        display.fill(0)
        display.text(' Valves Open', 36, 20, 1)
        time.sleep(.5)
    if current_program == "CIP" and buttone_was_pushed and program_running:
        # Make it run!
        display.fill(0)
    #if current_program == "CIP" and buttone_was_pushed and not program_running:
        # Make it run!
        #program_running = True
        #buttone_was_pushed = False
    if current_program == "Fil" and buttond_was_pushed and program_running:
        # Turn the program back off.
        # buttond_was_pushed = False
        # showMainScreen()
    #display.show()
burrito_poots
by burrito_poots on Thu Jun 03, 2021 3:17 pm
FIXED MY GHOSTING ISSUE! WOOOT!!!! Thanks a ton. I'll post back when I enevitably break something else lol.
        # Go there
burrito_poots
by burrito_poots on Thu Jun 03, 2021 5:01 pm
Alright, last bit!
import board
import displayio
import terminalio
import busio
import digitalio
# Use for I2C
i2c = board.I2C()
WIDTH = 128
HEIGHT = 64
BORDER = 2
import rotaryio
import time
kit = MotorKit()
text_area4 = label.Label(terminalio.FONT, text="Mode: Filling", scale=1, color=0xFFFFFF, x=0, y=5)
text_area5 = label.Label(terminalio.FONT, text="{ OFF", scale=1, color=0xFFFFFF, x=0, y=20)
text_area6 = label.Label(terminalio.FONT, text="  ON", scale=1, color=0xFFFFFF, x=0, y=35)
text_area7 = label.Label(terminalio.FONT, text=" Time:", scale=1, color=0xFFFFFF, x=36, y=20)
text_area8 = label.Label(terminalio.FONT, text="0.0", scale=1, color=0xFFFFFF, x=110, y=20)
text_area9 = label.Label(terminalio.FONT, text=" Foam Pulse:", scale=1, color=0xFFFFFF, x=36, y=35)
text_area10 = label.Label(terminalio.FONT, text="0", scale=1, color=0xFFFFFF, x=122, y=35)
text_area11 = label.Label(terminalio.FONT, text="Mode: CIP", scale=1, color=0xFFFFFF, x=0, y=5)
CIPscreen.append(text_area11)
text_area12 = label.Label(terminalio.FONT, text="{ OFF", scale=2, color=0xFFFFFF, x=0, y=20)
CIPscreen.append(text_area12)
text_area13 = label.Label(terminalio.FONT, text="  ON", scale=2, color=0xFFFFFF, x=0, y=35)
CIPscreen.append(text_area13)
text_area14 = label.Label(terminalio.FONT, text="Mode: CIP", scale=1, color=0xFFFFFF, x=0, y=50)
CIPscreen.append(text_area14)
#display.refresh()
while True:
        # Go there
        # Make it run!
    try:
        print("retrying!")
            print(positionA)
            print(positionB)
        # Button was pushed while fill program running so we want it off.
        # Switch it to off!
        text_area5.text = "{ OFF"
        text_area6.text = "  ON "
        if (range_mm >= 70): #"if program_running and (range_mm >= 70):" may need to update to this
            time.sleep(.75)
    try:
        print("retrying!")
        # We are on Monarch #or fill, and want CIP.
        # Go there
        display.show(CIPscreen)
        # Make it run!
        text_area12 = "  OFF"
        text_area13.text = "{ ON"
        time.sleep(.5)
        # Button was pushed and program running.
        # Make it stop!
        text_area12 = "{ OFF"
        text_area13.text = "  ON"
        # Make it run!
        # showMainScreen()
    #display.show()
On my CIPscreen, lines 202 through 233 specifically, my little "{ OFF" portion is sticking when I click my button when it should be showing " OFF" -- any idea why? I thought I had made it just like the others that resolved my issues.
burrito_poots
by g3holliday on Thu Jun 03, 2021 5:36 pm
Just for the sake of it, you reimported
import board
import displayio
import terminalio
import busio
import digitalio
g3holliday
by plitog on Sun Jun 06, 2021 6:19 pm
burrito_poots wrote:Alright, last bit!
On line 215, you have
Should that perhaps be
text_area12.text = "  OFF"
Line 227 is also missing the ".text" on the assignment.
plitog
