Broken Guide
Broken Guide
by MattPackwood on Fri May 14, 2021 8:12 pm
it looks like the latest libraries break the Covid Progress Tracker
https://learn.adafruit.com/adafruit-mag ... on-tracker
Matt
MattPackwood
Re: Broken Guide
by dastels on Fri May 14, 2021 10:54 pm
What, exactly, are you seeing?
dastels
Re: Broken Guide
by MattPackwood on Sat May 15, 2021 9:50 am
Sorry, I should have included this....
MattPackwood
Re: Broken Guide
by dastels on Sat May 15, 2021 10:23 am
I'm not seeing a problem looking at the code in the guide. Can you post exactly the code.py that's on the MagTag in case something is different that the code in the guide.
dastels
Re: Broken Guide
by MattPackwood on Sat May 15, 2021 2:14 pm
Here you go...
from adafruit_magtag.magtag import MagTag
from adafruit_progressbar.progressbar import ProgressBar
# Set up where we'll be fetching data from
DATA_SOURCE = "https://raw.githubusercontent.com/owid/covid-19-data/master/public/data/vaccinations/country_data/United%20States.csv"
# Find data for other countries/states here:
# https://github.com/owid/covid-19-data/tree/master/public/data/vaccinations
magtag = MagTag(url=DATA_SOURCE)
magtag.network.connect()
magtag.add_text(
    text_font="/fonts/ncenR14.pcf",
    text_position=((magtag.graphics.display.width // 2) - 1, 8,),
    text_anchor_point=(0.5, 0.5),
    is_data=False,
)  # Title
magtag.add_text(
    text_position=((magtag.graphics.display.width // 2) - 1, 23,),
    is_data=False,
)  # Date
magtag.add_text(
    text_position=((magtag.graphics.display.width // 2) - 1, 40,),
    is_data=False,
)  # Vaccinated text
magtag.add_text(
    text_position=((magtag.graphics.display.width // 2) - 1, 85,),
    is_data=False,
)  # Fully vaccinated text
BAR_WIDTH = magtag.graphics.display.width - 80
BAR_HEIGHT = 25
BAR_X = magtag.graphics.display.width // 2 - BAR_WIDTH // 2
progress_bar = ProgressBar(
    BAR_X, 50, BAR_WIDTH, BAR_HEIGHT, 1.0, bar_color=0x999999, outline_color=0x000000
progress_bar_1 = ProgressBar(
    BAR_X, 95, BAR_WIDTH, BAR_HEIGHT, 1.0, bar_color=0x999999, outline_color=0x000000
magtag.graphics.splash.append(progress_bar)
magtag.graphics.splash.append(progress_bar_1)
magtag.graphics.set_background("/bmps/background.bmp")
try:
    value = magtag.fetch().split("\n")[-2].split(",")
    print("Response is", value)
    vaccinated = int(value[-2]) / 331984513
    fully_vaccinated = int(value[-1]) / 331984513
    magtag.set_text(f"{value[0]} Vaccination Rates", 0, False)
    magtag.set_text(value[1], 1, False)
    magtag.set_text("Vaccinated: {:.2f}%".format(vaccinated * 100), 2, False)
    magtag.set_text(
        "Fully Vaccinated: {:.2f}%".format(fully_vaccinated * 100), 3, False
    progress_bar.progress = vaccinated
    progress_bar_1.progress = fully_vaccinated
    magtag.refresh()
    seconds_to_sleep = 24 * 60 * 60  # Sleep for one day
    print(f"Sleeping for {seconds_to_sleep} seconds")
    magtag.exit_and_deep_sleep(seconds_to_sleep)
except (ValueError, RuntimeError) as e:
    print("Some error occured, retrying! -", e)
MattPackwood
Re: Broken Guide
by MattPackwood on Sat May 15, 2021 2:17 pm
And I did a:
Matt-Packwoods-iMac:~ $ circup update --all
Found device at /Volumes/CIRCUITPY, running CircuitPython 6.2.0.
Downloading latest version information.
  [####################################]  100%
OK
Found 2 module[s] needing update.
Updated neopixel
Updated adafruit_progressbar
And it is working again, so it is a library issue (I guess)
MattPackwood
Re: Broken Guide
by dherrada on Tue Jun 01, 2021 10:49 am
Hi. I'm the author of the guide. Can you try again and see if it's still not working? It could have been fixed in one of the libraries. It also might just need you to copy the libraries over again. Weird stuff like that has happened to me a decent amount, especially on slightly less stable chips like the ESP32-S2
dherrada
