Import Error at IO Smart Planter
by berkozz on Sun May 16, 2021 6:44 am
There is an error code on my panel like this:
Auto-reload is on. Simply save files over USB to run them or enter REPL to disab le.
Press any key to enter the REPL. Use CTRL-D to reload.soft reboot
code.py output:
File "code.py", line 15, in <module>
File "adafruit_pyportal/__init__.py", line 33, in <module>
File "adafruit_pyportal/network.py", line 31, in <module>
File "adafruit_portalbase/network.py", line 29, in <module>
ImportError: no module named 'adafruit_fakerequests.Fake_Requests'
I found this file in the folder (adafruit_fakerequests) but it doesn't see this file. How can I solve this problem ?
berkozz
Re: Import Error at IO Smart Planter
by adafruit_support_carter on Tue May 18, 2021 2:54 pm
Is the file adafruit_fakerequests.py located in the lib folder of your CIRCUITPY drive? Like this:
CIRCUITPY/lib/adafruit_fakerequests.py
by berkozz on Wed May 19, 2021 4:34 pm
adafruit_support_carter wrote:Is the file adafruit_fakerequests.py located in the lib folder of your CIRCUITPY drive? Like this:
yes it is.
berkozz
by adafruit_support_carter on Thu May 20, 2021 1:54 pm
Not seeing it? Scroll up maybe?
There are two different files: adafruit_fakerequests.mpy and adafruit_requests.mpy.
In general, you want to have the .mpy versions in your lib folder.
by berkozz on Fri May 21, 2021 6:07 am
adafruit_support_carter wrote:Not seeing it? Scroll up maybe?
There are fakerequest and request files.
berkozz
by adafruit_support_carter on Fri May 21, 2021 11:03 am
It looks like you are ending up with both .py and .mpy versions of some of the library files. How are you downloading the libraries and installing them to the CIRCUITPY drive?
by berkozz on Fri May 21, 2021 2:52 pm
adafruit_support_carter wrote:It looks like you are ending up with both .py and .mpy versions of some of the library files. How are you downloading the libraries and installing them to the CIRCUITPY drive?
I think I accidentally copied adafruit-circuitpython-bundle-py-20210507's files into the lib folder
berkozz
by adafruit_support_carter on Mon May 24, 2021 1:09 pm
OK, that could be part of it. Go ahead and just start over with your lib folder. Just delete everything there and copy back over from a bundle file downloaded from here:
https://circuitpython.org/libraries
It should only contain .mpy versions, which is what you want.
by berkozz on Mon May 24, 2021 2:52 pm
adafruit_support_carter wrote:OK, that could be part of it. Go ahead and just start over with your lib folder. Just delete everything there and copy back over from a bundle file downloaded from here:
I did what you said. now I have this :)
code.py output:
No SD card found: no SD card
drawing background..
loading fonts...
File "code.py", line 132, in <module>
File "adafruit_bitmap_font/bdf.py", line 167, in load_glyphs
MemoryError: memory allocation failed, allocating 472 bytes
Code done running.
berkozz
by adafruit_support_carter on Mon May 24, 2021 3:16 pm
What board are you running this on? That looks like a running out of memory error :(
by berkozz on Tue May 25, 2021 1:59 am
adafruit_support_carter wrote:What board are you running this on? That looks like a running out of memory error :(
You mean circuitphyton version ? It is 6.2.0
berkozz
by adafruit_support_carter on Tue May 25, 2021 1:42 pm
The main board - like a Feather M4 Express? A Trinket M0? etc?
by berkozz on Wed May 26, 2021 1:22 am
adafruit_support_carter wrote:The main board - like a Feather M4 Express? A Trinket M0? etc?
Pyportal Titano
berkozz
by adafruit_support_carter on Wed May 26, 2021 11:33 am
Hmmm. A Titano shouldn't have any issues with that code. Just to be sure, this is the code you are trying to run?
https://learn.adafruit.com/pyportal-pet ... code-setup
by berkozz on Wed May 26, 2021 1:52 pm
adafruit_support_carter wrote:Hmmm. A Titano shouldn't have any issues with that code. Just to be sure, this is the code you are trying to run?
yes it is.. If I insert a sd card, will the problem be fixed?
berkozz
