Getting Pico(RP2040) to workwith DRV2605L breakout
by Morven on Tue Jun 01, 2021 7:48 pm
I am having trouble getting the pico to work over i2c with the DRV2605L. I followed the instructions in the these two posts, https://learn.adafruit.com/getting-started-with-raspberry-pi-pico-circuitpython/pinouts and https://learn.adafruit.com/adafruit-drv2605-haptic-controller-breakout/arduino-code?view=all to setup CircuitPython on the pico, I just want to run the sample as shown in the guide to play through the different preset affects:
import time
import board
import busio
import adafruit_drv2605
i2c = busio.I2C(board.GP1, board.GP0)
drv = adafruit_drv2605.DRV2605(i2c)
effect_id = 1
while True:
    print("Playing effect #{0}".format(effect_id))
    drv.sequence[0] = adafruit_drv2605.Effect(effect_id)
    drv.play()
    time.sleep(0.5)
    drv.stop()
    effect_id += 1
    if effect_id > 123:
        effect_id = 1
But I am getting and error complaining
RuntimeError: No pull up found on SDA or SCL; check your wiring
, which from my understanding through reading the guide in the seconf link and some google search, this breakout board should already have 10K pull ups build in, not sure what I am doing wrong here.
Currently I have GPIO 0(SDA) and 1(SCL) of the pico directly connected to the DRV2605L breakout sda and scl correspondingly, and 3v3out(pico) <-> Vin, GND<->GND. Is this wiring wrong, do I actually need to add some external pullup resistors? I also tried getting this to work through the PICO c/c++ sdk and micropython i2c scanner code, but the motor driver is not showing up with those methods either. Any help is appreciated, thanks a lot.
Morven
Re: Getting Pico(RP2040) to workwith DRV2605L breakout
by tannewt on Tue Jun 01, 2021 8:02 pm
What version of CircuitPython are you using? Make sure it's the latest (6.3.0 is being released now.) There was some I2C issues in older versions.
tannewt
by Morven on Tue Jun 01, 2021 8:11 pm
Thanks for the quick reply, Adafruit CircuitPython 6.2.0 on 2021-04-05; Raspberry Pi Pico with rp2040 is what I see when connected through minicom, I downloaded the uf2 from here https://circuitpython.org/board/raspberry_pi_pico/.
Morven
by Morven on Tue Jun 01, 2021 8:13 pm
Should I switch to 6.3.0, I was using 6.2.0 cause it still says unstable for 6.3.0
Morven
by Morven on Tue Jun 01, 2021 8:28 pm
Played around a bunch more, tried with the newer
Adafruit CircuitPython 6.3.0-rc.0 on 2021-05-25; Raspberry Pi Pico with rp2040
, and just sanity checking, I also tested a different pico and or DR2605L breakout, still getting the same error.
Morven
by tannewt on Wed Jun 02, 2021 11:16 am
Ya, generally with bugs its good to try the latest versions, even if the releases are unstable.
Please post a picture showing everything connected. This error often happens when things aren't well connected.
tannewt
by Morven on Thu Jun 03, 2021 6:55 am
Here's my current wiring. I have tried have straight jumper wires between them before, last thing I haven't tried is soldering them which I don't really want to do yet until get the setup working. Thanks for the help.
Wiring different angle
Wiring
Morven
by tannewt on Thu Jun 03, 2021 3:28 pm
You'll need to solder in the pin headers for a reliable connection. You could use a grabber to connect otherwise: https://www.pomonaelectronics.com/produ ... test-clips
tannewt
by Morven on Tue Jun 08, 2021 9:13 am
My orders of a soldering tools just arrived, and as you suggested soldering helped to keep reliable connections. Now it works as expected, thanks for you help.
Morven
by tannewt on Wed Jun 09, 2021 1:38 pm
Great! I'm glad it is working for you.
tannewt
