Failed to get response from VC0706
by JarrydStringy on Wed Jun 02, 2021 12:00 pm
I have a TTL Serial Camera connected to a Feather M0 Adalogger setup with Circuit Python. I am getting the following output when running my program:
File "main.py", line 30, in <module>
File "adafruit_vc0706.py", line 114, in __init__
RuntimeError: Failed to get response from VC0706, check wiring!
The code I am using is from page 26 on the guide: https://cdn-learn.adafruit.com/download ... camera.pdf
I know the camera is wired up correctly as I could produce an image through an Arduino Uno and I have followed the wiring for the Feather correctly. Just not sure what this error could be.
JarrydStringy
Re: Failed to get response from VC0706
by adafruit_support_carter on Wed Jun 02, 2021 12:12 pm
Try swapping TX/RX connections on one end. Looks like you have TX-TX and RX-RX:
https://learn.adafruit.com/ttl-serial-c ... -3005184-2
by JarrydStringy on Wed Jun 02, 2021 12:30 pm
I just got it working. I swapped the TX and RX around, but the problem also seems to also be through the 5V. I swapped from USB to battery and it worked. Thanks for the help.
JarrydStringy
