Code below:
# This example is CircuitPython from https://github.com/adafruit/circuitpython/pull/4802
# had to use https://raw.githubusercontent.com/adafruit/Adafruit_CircuitPython_ESP32SPI/f97db45bbe6072ae08c56773ba49eb9f5b779725/adafruit_esp32spi/adafruit_esp32spi_wsgiserver.py
import busio
import board
import digitalio
import adafruit_requests as requests
import adafruit_esp32spi.adafruit_esp32spi_socket as socket
from adafruit_esp32spi import adafruit_esp32spi_wsgiserver as server
from adafruit_wsgi.wsgi_app import WSGIApp
import secrets
esp32_cs = digitalio.DigitalInOut(board.CS1)
esp32_ready = digitalio.DigitalInOut(board.ESP_BUSY)
esp32_reset = digitalio.DigitalInOut(board.ESP_RESET)
spi = busio.SPI(board.SCK1, board.MOSI1, board.MISO1)
# Default:
#>>> spi.frequency
#7812500
while not spi.try_lock():
continue
spi.configure(baudrate=62500000)
spi.unlock()
#>>> spi.frequency
#62500000
esp = adafruit_esp32spi.ESP_SPIcontrol(spi, esp32_cs, esp32_ready, esp32_reset)
def connect():
esp.reset()
if esp.status == adafruit_esp32spi.WL_IDLE_STATUS:
print("ESP32 found and in idle mode")
print("Firmware vers.", esp.firmware_version)
print("MAC addr:", [hex(i) for i in esp.MAC_address])
print('Connecting to AP')
while not esp.is_connected:
print("Connecting...")
try:
esp.connect_AP(secrets.ssid, secrets.password)
except RuntimeError as e:
print("Failed to connect, retrying: ", e)
continue
print(f'Connected to {str(esp.ssid, "utf-8")}, RSSI: {esp.rssi}')
print(f'IP: {esp.pretty_ip(esp.ip_address)}')
app = WSGIApp()
@app.route("/test")
def webapp_test(request):
return('200 OK', [], ['a'] * 1024)
@app.route("/reboot")
def webapp_reboot(request):
print('Restarting')
import microcontroller
microcontroller.reset()
@app.route("/reconnect")
def webapp_reconnect(request):
esp.reset()
led = digitalio.DigitalInOut(board.LED)
led.direction = digitalio.Direction.OUTPUT
connect()
server.set_interface(esp)
wsgiServer = server.WSGIServer(80, application=app)
wsgiServer.start()
while True:
try:
wsgiServer.update_poll()
# other stuff
except (TypeError, ValueError, RuntimeError) as e:
connect()
wsgiServer.start()
# Version:
#Adafruit CircuitPython 7.0.0-alpha.2-646-g7df5d74d9 on 2021-05-22; Arduino Nano RP2040 Connect with rp2040
# Output:
#ESP32 found and in idle mode
#Firmware vers. bytearray(b'1.4.5\x00')
#MAC addr: <macid>
#Connecting to AP
#Connecting...
#Connected to <ssid>, RSSI: -38
#IP: <IP>
#closing
# Client:
#$ wget <IP>/test
#--2021-06-03 14:47:48-- http://<IP>/test
#Connecting to <IP>:80... connected.
#HTTP request sent, awaiting response... 200 OK
#Length: unspecified
#Saving to: ‘test’
#test [ <=> ] 1.00K 68.4 B/s in 15s
#2021-06-03 14:48:03 (68.6 B/s) - ‘test’ saved [1024]
