Metro M4 Express not showing up as CIRCUITPY
by parsko on Fri Jun 04, 2021 10:31 am
I have my Metro M4 Express plugged in via USB, but I don't see "CIRCUITPY", only "USB Drive" in my windows file explorer.
I have updated the UF2 bootloader to v3.13.0
I have updated to circuitpython v 6.3 (I tried v7 also, same result).
I just deleted everything, then re-updated the UF2 and CP again, still only see "USB Drive" in file explorer.
I am able to write code to code.py, then save the first time. I can see print statements being written out to REPL. But, if I make a change (for instance, adding one extra blank line, then save) the REPL breaks, and I can no longer see the REPL. I have to reset the board to be able to see REPL again.
I have tried multiple USB port configurations, all with the same result.
Any thoughts?
Thanks,
-Parsko
parsko
Re: Metro M4 Express not showing up as CIRCUITPY
by tannewt on Fri Jun 04, 2021 12:10 pm
Sounds like your file system may be unhappy. From the repl you can reformat it: https://learn.adafruit.com/welcome-to-c ... 2978456-23 (Save what you can before you do this.)
tannewt
by parsko on Fri Jun 04, 2021 1:41 pm
Thanks Tan! Your link worked great. I can see "CIRCUITPY" once again.
-Parsko
parsko
