Adafruit MCP4728 Quad DAC with EEPROM - STEMMA QT / Qwiic
by AAires on Sat Jun 05, 2021 3:47 pm
Hi there,
I'm building a project with a raspberry pi pico and an Adafruit MCP4728 Quad DAC with EEPROM - STEMMA QT / Qwiic using MICROPYTHON.
I would like to ask your help to the following, is it possible to apply the formula DAC OUTPUT= 2.59*(DAC VALUE)-1.29 to DAC outputs?
Example:
the module receives a 12-bit value 2696 that equals to a 3.3V output, but I need to convert it to 7.3 with that formula.
Thanks for your help.
Best regards
AAires
Re: Adafruit MCP4728 Quad DAC with EEPROM - STEMMA QT / Qwii
by adafruit_support_mike on Sun Jun 06, 2021 8:09 pm
I can't think of any reason why it wouldn't work. You can calculate any value you want.
by AAires on Thu Jun 10, 2021 3:34 pm
Thanks for your Replay. Could you tell me how to do it?
I'm using the mcp4728.py found até Github.... https://github.com/adafruit/Adafruit_MCP4728
Many thanks
AAires
by adafruit_support_mike on Fri Jun 11, 2021 8:14 pm
You already have the equation above. Just use that in your code.
by AAires on Fri Jun 11, 2021 8:28 pm
Ok
Sorry but I do not have any experience with Micropython ando do not know how to do it.
Could you be so kind to Help me.
Many thanks!
AAires
by adafruit_support_mike on Sat Jun 12, 2021 6:34 am
We don't do on-demand programming. You'll need to learn enough of the language to make the change on your own.
Math is fairly easy in Python, so learning shouldn't take long.
by AAires on Sat Jun 12, 2021 6:51 am
Ok
I'm ONLY struggle to identify the output "object" to apply the equation.
AAires
cron
