DPS310 Issues with Circuitpython
by jimhill on Sun Jun 06, 2021 5:57 am
We're trying to get a DPS310 sensor working on a Raspberry Pico and are having some issues. We have booted the Pico to use circuit python and think we have put all of the relevant libraries in the lib folder. However, when we try to run the code we get an error that we're struggling to understand. Please could anyone help?
The error message is:
File "<stdin>", line 5, in <module>
File "/lib/adafruit_dps310.py", line 192, in __init__
AttributeError: 'int' object has no attribute 'try_lock'
The code that we've written is:
from adafruit_dps310 import DPS310
from time import sleep
import board
alti = DPS310(0, 1)
while True:
    print("Temperature = %.2f *C" % dps310.temperature)
    print("Pressure = %.2f hPa" % dps310.pressure)
    print("")
    sleep(1)
jimhill
Re: DPS310 Issues with Circuitpython
by wildestpixel on Mon Jun 07, 2021 12:59 am
You have to initialise the i2c device, and as the Pico does not have board assignations like a feather for example, you will have to identify the SCL and SDA pins manually :
Would therefore look something like this attached to GP21 and GP20
import time
import busio
import adafruit_dps310
i2c = busio.I2C(board.GP21, board.GP20)
dps310 = adafruit_dps310.DPS310(i2c)
while True:
    print("")
    time.sleep(1.0)
Check also for your sanity - you defined "alti", but didn't call it again (not that it would have made difference) - use the examples and modify from there only to make it work. Above should be a good pointer.
wildestpixel
