No pull up found on SDA or SCL; check your wiring No I2C dev
Re: No pull up found on SDA or SCL; check your wiring No I2C
by timmcc on Mon Jun 07, 2021 3:59 pm
Yup.
Screen Shot 2021-06-07 at 3.54.42 PM (2).png (537.72 KiB) Viewed 100 times
timmcc
by adafruit_support_carter on Mon Jun 07, 2021 4:03 pm
OK. Thanks. Really weird. It seems like a connection issue. Try removing the motor and speaker wires connected to the Crickit just to get them out of the setup for now. Then go over the bolts again. Maybe even try just removing them all and reattaching them. See if maybe they just need to "seat" better? You can check with the I2C scan test from REPL.
by timmcc on Mon Jun 07, 2021 4:17 pm
I unscrewed the whole thing and put it back together and tightened the screws/bolts. Ran the i2c scan test in the REPL. Same thing. It returned an empty list.
timmcc
by adafruit_support_carter on Mon Jun 07, 2021 4:35 pm
OK, let's go ahead and try updating the Crickit firmware just to see if that helps at all. Try the process outlined here:
https://learn.adafruit.com/adafruit-cri ... ur-crickit
and then try the scan again.
