Getting started with the M4 Airlift board and a 3.5-tft touc
by Daqar on Wed Jun 09, 2021 12:07 pm
Hi guys,
I'm going to have to ask a total n00b question, that has probably been asked before to the point of pain. I got a Metro M4 Airlift board and an Adafruit 3.5 tft touchscreen. I'm having an uphill battle figuring out how to get started. I have the arduino starterkit with the project, for reference. So I have a breadboard, wires, cables and a small collection of bits and doodads.
I bought the M4 board and touchscreen with the express purpose of building a digital dice-roller for an upcoming Shadowrun game. I can figure out how to make the dice-roller itself in python. But I have trouble finding relevant tutorials on how to properly connect the screen to the M4 board and how to program something resembling a user interface.
I need help with:
1.) Properly connecting the board and tft screen, using the SPI-side of the tft board.
2.) Make sure I've set things up properly with the IDE's, I'm gonna use the MU-editor as I can't figure out how to use either VS code or PyCharm.
3.) Learn how to display data on the screen and take inputs from it.
I can find tutorials on how to connect the screen to an arduino and I can find tutorials on how to program the screen, but that's either using an arduino or a different board than the M4. I do not have the technical insight to determine if I can use an arduino-tutorial to hook it up, and then a tutorial for a different board for programming. The learning path seems very unclear.
I know I'm asking a lot of you guys and I hope it doesn't come off as demanding, because I don't intent it to be.
Happy hacking and making! :)
Daqar
Daqar
Re: Getting started with the M4 Airlift board and a 3.5-tft
by dastels on Wed Jun 09, 2021 12:18 pm
You mean this display? https://learn.adafruit.com/adafruit-3-5-color-320x480-tft-touchscreen-breakout
For wiring, have a look at https://learn.adafruit.com/adafruit-3-5-color-320x480-tft-touchscreen-breakout/spi-wiring-and-test, though you should use the SPI connector (the 2x3 header next to the LEDs at the end farthest from the USB connector, see https://learn.adafruit.com/adafruit-metro-m4-express-airlift-wifi/pinouts-2). You'll also need a GPIO pins for CS and DC (see the linked TFT guide page)
Here's a place to start with using the display with CircuitPython, specifically using displayio: https://learn.adafruit.com/adafruit-3-5-color-320x480-tft-touchscreen-breakout/3-5-tft-featherwing.
More generally, have a look at https://learn.adafruit.com/circuitpython-display-support-using-displayio, and https://learn.adafruit.com/making-a-pyportal-user-interface-displayio will be useful as well (even though it talks about PyPortal.
The general/introductory CircuitPython guide is https://learn.adafruit.com/welcome-to-circuitpython.
dastels
by Daqar on Wed Jun 09, 2021 12:56 pm
dastels wrote:You mean this display? https://learn.adafruit.com/adafruit-3-5-color-320x480-tft-touchscreen-breakout
Hi Dave,
Thanks for the tip. I'm trying to wire it up as you suggest. I'm running into an issue. On the Board, in the SPI-section you mentioned. There is a pin called "SCK". There is no "SCK" on the screen? Is it the same as "CLK"?
These are the connections I've done:
Board: TFT-screen:
GND ---> GND (The one at the very end of the row of headers) There are two pins on the screen-board called "GND"...
RST ---> RST
SCK ---> ???
MOSI ---> MOSI
MISO ---> MISO
5V ---> Vin
Is that all it needs?
Daqar
by dastels on Wed Jun 09, 2021 1:04 pm
Yes. CLK = "clock", SCK = "SPI clock", same thing, different label.
Your connections look good.
dastels
by Daqar on Wed Jun 09, 2021 1:12 pm
Cool. Thanks for the help, much appreciated. Now I can dive into the programming bit! :D
/Daqar
Daqar
