PyPortal Weather Station debug issues
janowatzki
Post by janowatzki »
New to Circuit Python. So Im trying to do: https://learn.adafruit.com/pyportal-sma ... cuitpython
Im getting this:
File "code.py", line 49, in <module>
AttributeError: 'module' object has no attribute 'set_socket'
I attached the code.py
Thank you.
code.py
the code.py from the project
(2.61 KiB) Downloaded 4 times
mikeysklar
Re: PyPortal Weather Station debug issues
Post by mikeysklar »
We should probably start with making sure your CircuitPython installation is the current stable release and the required libraries that go into CIRCUITPY/lib are all current.
https://circuitpython.org/board/pyportal/
janowatzki
Reloaded everything and it got worse I think. Here is a screenshot. Down in the serial window the m105 stuff, on the actual portal, it fills up half the screen.
Screenshot from 2021-06-11 14-35-44.png (164.93 KiB) Viewed 187 times
janowatzki
power outage and when the lights came back on it works.... damn odd.
thanks.
