So with my code below I'm having an issue figuring out how to debounce the buttons that I use. Right now I'm using a time.sleep option which works, but I'd like to go about doing this the correct way. But when I try to implement what I'm seeing here: https://www.youtube.com/watch?v=ktlRv83UvjY it doesn't work and I'm not really sure why that is.
Also, for my code logic: right now, I have two subprograms that I run ("Fil" and "CIP") -- the way my code is set up, switching between these with button_d works fine, but I can't wrap my head around the logic design for allowing a third subprogram, so I can cycle between them all. Any ideas on how to accomplish that? As best as I understand it, currently the logic I have setup only allows for the back and forth between the two subprograms. Thanks in advance!
import board
import displayio
import terminalio
import busio
import digitalio
import adafruit_displayio_sh1107
from adafruit_display_shapes.roundrect import RoundRect
from adafruit_display_shapes.rect import Rect
from adafruit_display_shapes.circle import Circle
from adafruit_display_shapes.triangle import Triangle
from adafruit_display_text import label
displayio.release_displays()
# old_reset = board.D9
# Use for I2C
i2c = board.I2C()
display_bus = displayio.I2CDisplay(i2c, device_address=0x3C)
# SH1107 is vertically oriented 64x128
WIDTH = 128
HEIGHT = 64
BORDER = 2
display = adafruit_displayio_sh1107.SH1107(display_bus, width=WIDTH, height=HEIGHT)
color_bitmap = displayio.Bitmap(WIDTH, HEIGHT, 1)
color_palette = displayio.Palette(1)
color_palette[0] = 0xFFFFFF # White
# Make the display context
splash = displayio.Group()
display.show(splash)
fillscreen = displayio.Group()
CIPscreen = displayio.Group()
dropleticon = displayio.Group()
bubbleicon = displayio.Group()
import rotaryio
import time
from adafruit_motorkit import MotorKit
import adafruit_vl6180x
from adafruit_debouncer import Debouncer
sensor = adafruit_vl6180x.VL6180X(i2c)
encoderB = rotaryio.IncrementalEncoder(board.D12, board.D11)
button_e = digitalio.DigitalInOut(board.D10)
button_e.direction = digitalio.Direction.INPUT
button_e.pull = digitalio.Pull.UP
switch_e = Debouncer(button_e)
encoderA = rotaryio.IncrementalEncoder(board.A4, board.A3)
button_d = digitalio.DigitalInOut(board.A2)
button_d.direction = digitalio.Direction.INPUT
button_d.pull = digitalio.Pull.UP
switch_d = Debouncer(button_d)
range_mm = sensor.range
kit = MotorKit()
buttond_was_pushed = False
buttone_was_pushed = False
current_program = "Monarch"
program_running = False
lastA_position = None
lastB_position = None
text_area = label.Label(terminalio.FONT, text="monarch", scale=3, color=0xFFFFFF, x=3, y=12)
splash.append(text_area)
text_area2 = label.Label(terminalio.FONT, text="FLUID SYSTEMS", scale=1, color=0xFFFFFF, x=28, y=36)
splash.append(text_area2)
text_area3 = label.Label(terminalio.FONT, text="nano MK.I", scale=1, color=0xFFFFFF, x=70, y=55)
splash.append(text_area3)
# Draw some white squares
sm_bitmap = displayio.Bitmap(20, 12, 1)
sm_square = displayio.TileGrid(sm_bitmap, pixel_shader=color_palette, x=83, y=0)
fillscreen.append(sm_square)
sm_bitmapCIP = displayio.Bitmap(20, 12, 1)
sm_squareCIP = displayio.TileGrid(sm_bitmapCIP, pixel_shader=color_palette, x=83, y=0)
CIPscreen.append(sm_squareCIP)
triangle = Triangle(40, 18, 37, 25, 43, 25, fill=0x000000, outline=0xFFFFFF)
dropleticon.append(triangle)
circle = Circle(40, 25, 3, fill=0x000000, outline=0xFFFFFF)
dropleticon.append(circle)
rectDroplet = Rect(39, 22, 3, 1, fill=0x000000)
dropleticon.append(rectDroplet)
dropleticon.x = 27
dropleticon.y = -17
fillscreen.append(dropleticon)
circle2 = Circle(68, 43, 3, fill=0x000000, outline=0xFFFFFF)
bubbleicon.append(circle2)
circle3 = Circle(64, 46, 4, fill=0x000000, outline=0xFFFFFF)
bubbleicon.append(circle3)
circle4 = Circle(70, 49, 3, fill=0x000000, outline=0xFFFFFF)
bubbleicon.append(circle4)
bubbleicon.x = 3
bubbleicon.y = -40
CIPscreen.append(bubbleicon)
rectTime = Rect(3, 29, 58, 34, outline=0xFFFFFF)
fillscreen.append(rectTime)
rectFoam = Rect(77, 29, 43, 34, outline=0xFFFFFF)
fillscreen.append(rectFoam)
roundrectTime = RoundRect(0, 22, 33, 15, 7, fill=0xFFFFFF, stroke=1)
fillscreen.append(roundrectTime)
roundrectFoam = RoundRect(74, 22, 38, 15, 7, fill=0xFFFFFF, stroke=1)
fillscreen.append(roundrectFoam)
text_area4 = label.Label(terminalio.FONT, text="Fill Mode:", scale=1, color=0xFFFFFF, x=0, y=5)
fillscreen.append(text_area4)
text_area5 = label.Label(terminalio.FONT, text="OFF", scale=1, color=0x000000, x=85, y=5)
fillscreen.append(text_area5)
text_area6 = label.Label(terminalio.FONT, text="ON", scale=1, color=0xFFFFFF, x=110, y=5)
fillscreen.append(text_area6)
text_area7 = label.Label(terminalio.FONT, text="Time", scale=1, color=0x000000, x=5, y=28)
fillscreen.append(text_area7)
text_area8 = label.Label(terminalio.FONT, text="0.0", scale=2, color=0xFFFFFF, x=8, y=47)
fillscreen.append(text_area8)
text_area9 = label.Label(terminalio.FONT, text="Pulse", scale=1, color=0x000000, x=79, y=28)
fillscreen.append(text_area9)
text_area10 = label.Label(terminalio.FONT, text="0", scale=2, color=0xFFFFFF, x=90, y=47)
fillscreen.append(text_area10)
text_area11 = label.Label(terminalio.FONT, text=" CIP Mode:", scale=1, color=0xFFFFFF, x=0, y=5)
CIPscreen.append(text_area11)
text_area12 = label.Label(terminalio.FONT, text="OFF", scale=1, color=0x000000, x=85, y=5)
CIPscreen.append(text_area12)
text_area13 = label.Label(terminalio.FONT, text="ON", scale=1, color=0xFFFFFF, x=110, y=5)
CIPscreen.append(text_area13)
triangle2 = Triangle(26, 22, 6, 62, 46, 62, fill=0xFFFFFF)
CIPscreen.append(triangle2)
triangle3 = Triangle(26, 50, 24, 34, 28, 34, fill=0x000000)
CIPscreen.append(triangle3)
circle5 = Circle(26, 57, 2, fill=0x000000)
CIPscreen.append(circle5)
circle6 = Circle(26, 33, 2, fill=0x000000)
CIPscreen.append(circle6)
text_area15 = label.Label(terminalio.FONT, text="WARNING:", scale=1, color=0xFFFFFF, x=64, y=25)
CIPscreen.append(text_area15)
text_area16 = label.Label(terminalio.FONT, text="Valves will", scale=1, color=0xFFFFFF, x=55, y=41)
CIPscreen.append(text_area16)
text_area17 = label.Label(terminalio.FONT, text="stay open!", scale=1, color=0xFFFFFF, x=59, y=53)
CIPscreen.append(text_area17)
#display.refresh()
while True:
#dropleticon = displayio.Group()
if button_d.value == 0:
# Button_d has been pressed
buttond_was_pushed = True
time.sleep(.10)
if button_e.value == 0:
# Button_e has been pressed
buttone_was_pushed = True
time.sleep(.10)
#if current_program == "Monarch" and buttond_was_pushed:
if current_program != "Fil" and buttond_was_pushed:
# We are on main screen or CIP, but want Fil.
# Go there
display.show(fillscreen)
current_program = "Fil"
if current_program == "Fil" and buttone_was_pushed and not program_running:
# Button was pushed, but program not yet running.
# Make it run!
program_running = True
#try:
#range_mm = sensor.range
#print('Range: {0}mm'.format(range_mm))
#except RuntimeError:
#print("retrying!")
# time.sleep(.00001)
if current_program == "Fil" and not buttone_was_pushed and program_running:
# Fill program running, but button is not pushed... now what?
positionA = encoderA.position
if lastA_position is None or positionA != lastA_position:
print(positionA)
lastA_position = positionA
timingA_value = 0.1*encoderA.position
#print(timingA_value) # can remove this once verified it works
sm_square.x = 106
text_area5.color = 0xFFFFFF
text_area6.color = 0x000000
text_area8.text = str(timingA_value)
triangle.fill = 0xFFFFFF
triangle.outline = 0xFFFFFF
circle.fill = 0xFFFFFF
circle.outline = 0xFFFFFF
rectDroplet.fill = 0xFFFFFF
positionB = encoderB.position
if lastB_position is None or positionB != lastB_position:
print(positionB)
lastB_position = positionB
timingB_value = encoderB.position
#print(timingB_value) # can remove this once verified it works
text_area10.text = str(timingB_value)
if current_program == "Fil" and buttone_was_pushed and program_running:
# Button was pushed while fill program running so we want it off.
# Switch it to off!
sm_square.x = 83
text_area5.color = 0x000000
text_area6.color = 0xFFFFFF
triangle.fill = 0x000000
circle.fill = 0x000000
rectDroplet.fill = 0x000000
if (range_mm >= 70): #"if program_running and (range_mm >= 70):" may need to update to this
kit.motor2.throttle = 1.0 # Load can
time.sleep(.8) # Piston extension time
kit.motor2.throttle = 0 # Piston retract
time.sleep(1) # need for can to fall into chute
kit.motor4.throttle = 1.0 # Drop lift piston
kit.motor1.throttle = 1.0 # Start Purge
time.sleep(1.5) # Hold for 1.5 s
kit.motor1.throttle = 0 # Stop Purge
kit.motor3.throttle = 1.0 # Start Fill
time.sleep(timingA_value) # Hold for set time
kit.motor3.throttle = 0 # End fill
for _ in range(timingB_value):
time.sleep(0.05) # Hold for set time
kit.motor3.throttle = 1.0 # Start Foam Pulse
kit.motor3.throttle = 0 # End Foam Pulse
kit.motor4.throttle = 0 # Raise lift
time.sleep(.75)
#try:
#print('Range2: {0}mm'.format(range_mm))
#print("retrying!")
if current_program != "CIP" and buttond_was_pushed:
# We are on Monarch #or fill, and want CIP.
# Go there
display.show(CIPscreen)
time.sleep(.20)
triangle2.fill = 0x000000
triangle3.fill = 0xFFFFFF
circle5.fill = 0xFFFFFF
circle6.fill = 0xFFFFFF
time.sleep(.20)
triangle2.fill = 0xFFFFFF
triangle3.fill = 0x000000
circle5.fill = 0x000000
circle6.fill = 0x000000
time.sleep(.20)
time.sleep(.20)
kit.motor4.throttle = 0.0
kit.motor3.throttle = 0.0
current_program = "CIP"
if current_program == "CIP" and buttone_was_pushed and not program_running:
# Make it run!
sm_squareCIP.x = 106
text_area12.color = 0xFFFFFF
text_area13.color = 0x000000
circle2.fill = 0xFFFFFF
circle2.outline = 0xFFFFFF
circle3.fill = 0xFFFFFF
circle3.outline = 0xFFFFFF
circle4.fill = 0xFFFFFF
circle4.outline = 0xFFFFFF
time.sleep(.5)
if current_program == "CIP" and buttone_was_pushed and program_running:
# Button was pushed and program running.
# Make it stop!
sm_squareCIP.x = 83
text_area12.color = 0x000000
text_area13.color = 0xFFFFFF
circle2.fill = 0x000000
circle3.fill = 0x000000
circle4.fill = 0x000000
