I've upgraded a device that had been showing:
advertisement.complete_name
with a specific device name, like:
advertisement.complete_name = "ProfGsTie"
ble.start_advertising(advertisement)
When I upgraded to CircuitPython 6.3.0, all of a sudden this code doesn't seem to show the complete_name in the Bluefruit app. Instead it just shows some generic CIRCUITPY.
I've tried turning off bluetooth, turning it back on on tbe iOS device, quitting and restarting the app, even restarting the device. Still no luck.
Even more strange, when I run the Bluefruit Connect app on an iPad or macOS, I don't see the device there at all, even though I have the same standard settings as the iPhone (image below).
Any thoughts on what I might be doing wrong? Thanks! John
Bluefruit advertisement.complete_name not showing
- gallaugher
- mikeysklar
Re: Bluefruit advertisement.complete_name not showing
What hardware are you running on for the BLE controller?
When you upgraded to 6.3.0 did you also trash the /lib folders and replace all the necessary libraries with the 6.3.0 current release?
In case something else has changed does it work with short_name?
https://circuitpython.readthedocs.io/pr ... ising.html
advertisement.short_name
- kevinjwalters
I see you only have two out of four bars in signal strength, has that changed with the upgrade? Have you got same RSSI filtering value set when you use other devices? Doesn't seem likely that changes here would affect the long name but there was talk about adding control over transmit power GitHub: adafruit/circuitpython: Add transmit power control to BLE #2818.
- kevinjwalters
I asked and that didn't go into 6.3.0 via https://github.com/adafruit/circuitpyth ... nt-8652910
- tannewt
Did you forget the device in iOS? The host OSes tend to cache info. The device name is also fetched over GATT once the connection is established and will override the name from the advertisement. I think the Adapter class has a way to set the name for the GATT response.
