Expected output from BME688?
Technodad
Post by Technodad »
I have a BME688 hooked up to a Funhouse via i2c. The temperature and humidity data seems OK, but calling bme680.gas returns 12946860 ohm, and hasn’t changed over the past 24 hrs. (Code is from https://learn.adafruit.com/adafruit-bme ... 2997980-18, tweaked for the alternate i2c address.)
What’s a reasonable resistance value? Do I have a code problem, bad chip, something else?
tannewt
Re: Expected output from BME688?
Post by tannewt »
What exact product do you have? It sounds like the library for the BME680 isn't fully compatible with the BME688.
Technodad
Post by Technodad »
I have the Adafruit BME688 STEMMA QT Product ID: 5046. It’s connected to the FunHouse by the 50mm STEMMA QT cable. The library was the BME680 library from the Adafruit site - I don’t believe there is a separate 688 library.
It’s possible that there is a difference in initialization or timing, but I’d expect more reports of problems.
I plan to do some testing from a Pi tomorrow, hopefully both CircuitPython and Node-RED.
tannewt
Post by tannewt »
Thanks for the details. I don't have one of these myself so let me find one of our support folks who do. Thanks for your patience!
Technodad
Post by Technodad »
I’ve put together a test program in CircuitPython in a Pi, and I’m seeing the same data coming from the sensor as on the code running on the FunHouse. The MBE688 is communicating with the program, and the temperature, pressure, and RH readings seem correct and responsive. The gas resistance however is stuck at 12946860 Ohms.
I’ll give Node-Red a try, in case this is a library problem, but I’m increasingly coming to the conclusion I have a duff sensor.
Technodad
Post by Technodad »
Well it turns out that someone had already contributed a Node-Red node for the BME680https://flows.nodered.org/node/node-red ... bme680-rpi, based on the Pimoroni BME680 library https://learn.pimoroni.com/tutorial/san ... 0-breakout. This saved me from having to use i2c directly, and made the test trivial. Unfortunately, the results were the same - the Gas sensor is stuck at 13MOhm, the same shown by the CircuitPython test.
As the sensor has now been tested in two different frameworks, I'm assuming it was DOA. On the plus side, I learned a lot!
Screen Shot 2021-07-10 at 2.03.49 PM.png (182.36 KiB) Viewed 225 times
adafruit_support_carter
This may be due to differences between the BME680 and BME688 specific to reading the gas resistance.
From the BME680 datasheet:
From the BME688 datasheet:
That would explain why the Node Red library did not work either. I'd suggest opening a new issue in the library repo:
https://github.com/adafruit/Adafruit_Ci ... 680/issues
Technodad
Post by Technodad »
Thanks, @adafruit_support_carter - glad to hear it might not be a dead sensor. Opened issue #42 on the library.
Sorry this took so long. There was some discussion about best way to integrate the updates that sort of stalled. The fix is now merged and available in the 3.4.0 release:
https://github.com/adafruit/Adafruit_Ci ... /tag/3.4.0
