I am a big fan of the MatrixPortal M4 and am very impressed on how much performance you got out of a simple Cortex M4. Well done!
But there is one issue that prevents it from being awesome: the undersized RAM. You see, the MatrixPortal M4 has significant RAM requirements to drive the display, handle the web queries and other JSON packing/unpacking, while running CircuitPython.
I've often had random issues running my code until I realized that the board was simply running out of memory.
Rather drastic optimization and frequent use of gc.collect have helped somewhat, but I still think that the board doesn't have enough memory for the intended purpose.
And while writing code in CircuitPython is awesome, I have the feeling that I am spending more time troubleshooting Out of Memory issues than writing useful code. Might as well switch to C++
Now, I believe that the ATSAMD51J20A would give quite a lot more memory, while being highly compatible wit the J19A thart you are currently using. Is this something that you might consider?
Or would have other suggestions?
Hope for a MatrixPortal M4 with more RAM?
- blnkjns
Re: Hope for a MatrixPortal M4 with more RAM?
Maybe you can offload some stuff to the ESP32. That chip is also pretty powerful.
C++ is another option, it will greatly reduce memory footprint.
Third route could be a second microcontroller just for the display, and make that behave as an I2C device to the other board.
- sermann
Hi blnkjns,
yes, I can do all these - if I have to, but I think that it would go against the whole idea of the product - it is supposed to be a controller that allows building a web-conneceted HUB75 display, but it doesn't have enough RAM to do that, except for the simplest cases.
I did notice that the PyPortal(s) use the ATSAMD51J20, which does seem more appropriate for web-connected devices, and wished Adafruit would consider releasing a version of the MatrixPortal based on that chip, or on an M7 maybe.
For my project, I guess I'll have to switch to a Raspberry Pi (with a HUB75 bonnet) and see how well CircuitPython runs on it... That might be an interesting ride...
Anyway, thanks for the suggestions.
Cheers,
Stephen
Cheers,
Stephen
