i2c communicate between circuitpython boards
- gsrobotics2017
don't know if I'm in the right place but iv got a pyportal Titano and a feather 2040 I am trying to communicate between the 2 with i2c but can't find any way to do this I'm happy to move to a different communication method lice UART or USB but I can't find anything on this ether does anyone have any advice?
- dastels
Re: i2c communicate between circuitpython boards
You can use the i2cperipheral module. See the docs as https://circuitpython.readthedocs.io/en ... index.html.
The Feather RP2040 doesn't include i2cperipheral in its CircuitPython build, but the Titano does. So the Titano will have to be the peripheral and the Feather, the host.
See https://circuitpython.readthedocs.io/en ... atrix.html for which core modules are included on each board.
- gsrobotics2017
do you know any way of adding this module to the father 2040
- dastels
I do not. There's an open issue to add it, but it's a low priority at the moment: https://github.com/adafruit/circuitpython/issues/4536.
- gsrobotics2017
do you understand how that paceg works
- dastels
"paceg"??
- gsrobotics2017
the i2cperipheral pacage
- dastels
"package"
In this case it's more correctly referred to as a module.
As for how it works. I linked to the docs which includes an example. From the other device (with sda, scl, and ground connected between the two boards) you use it like any I2C device, based on how you programmed it to respond.
That, as far as I know, is the extent of it.
- gsrobotics2017
I looked at the documentation but i cant understand it
- dastels
Is there anything in particular that is a problem?
- gsrobotics2017
i just don't understand the documentations
