Hi All,
I feel like I’m missing something obvious here, but I can’t seem to find any info on saving-to/reading-from the optional GD25Q16 - 2MB SPI Flash chip on a Adafruit QT Py - SAMD21 Dev Board using Circuit Python.
Project is basically a data logger with the need for data to be saved in non-volatile memory.
I hope someone can point me to an example or let me know if it’s something simple I’ve missed!
- Thanks
QT PY: 2Kb SPI Flash Access
- Franklin97355
Re: QT PY: 2Kb SPI Flash Access
Take a look at these and see if they help:
https://learn.adafruit.com/micropython- ... e-sd-cards
https://learn.adafruit.com/adafruit-spi-flash-sd-card
- Lansteys
Thanks for that!
I’m just working through it now - though I can’t seem to identify the CS pin for the Flash chip…?
Seems to be pin 11, PA08 but I’m stuck on figuring out how to put that in this line:
‘board.SD_CS’ isn’t valid and I’m not sure what I need to replace this with. I haven’t found what PA08 is in ‘board’. Any clues?
Any help would be greatly appreciated!
cs = digitalio.DigitalInOut(board.SD_CS)
- Lansteys
Ok, minor update:
Returns: “ValueError: PA08 in use”
I’ll keep trying to figure it out…
cs = digitalio.DigitalInOut(microcontroller.pin.PA08)
- tannewt
After you've soldered the optional flash onto the QT Py you'll want to switch to the Haxpress board build of CircuitPython. It'll use the SPI for the filesystem and then you can follow this guide for datalogging: https://learn.adafruit.com/cpu-temperat ... uit-python
Flash info is here: https://learn.adafruit.com/adafruit-qt- ... 3073285-12
- Lansteys
Hey, thanks for your reply!
Yes, have the Haxpress version installed. From memory the drive shows up with the full memory on my PC.
So if I understand correctly, there is no way to specifically save data to the Flash chip? Or is it that I can only save data to the Flash chip? (this would be OK)
I believe the Flash chip is rated for far more read/write cycles than the microcontrollers flash memory so it would be preferable to always use this.
- tannewt
The haxpress version of CircuitPython will write to the external flash only. The non-haxpress version will write to the internal flash. There isn't a version that will do both.
I haven't heard of anyone wearing out their flash with CircuitPython.
- Lansteys
Thanks again!
Yes, probably worried over nothing on that account, but that also answers my question - I don’t need to do anything special to utilise the external flash chip as long as the haxpress version of CP is installed.
Exactly what I needed to know - thanks!
