Anyone out there in forum land tried using the Bluefruit LE UART Friend with a qt py? Any code examples and/or wiring diagrams out there? I'm building a remotely controlled xylophone with a qt py rp2040. The qt py is plugged into an AW9523 gpio expander, which has the connections to the solenoid circuits. My next step is to add bluetooth and have it listen to messages from another microcontroller. Thoughts? Links?
Cheers,
Stuart
bluefruit le uart friend and qt py? Anyone tried this?
- plasnid
- mikeysklar
Re: bluefruit le uart friend and qt py? Anyone tried this?
Stuart,
The Bluefruit Friend UART should be straight forward to use with QtPy. You have UART pins available so follow these two guides:
https://learn.adafruit.com/introducing- ... art-friend
https://learn.adafruit.com/adafruit-qt-py-2040/pinouts
- plasnid
Thanks for your reply. The wiring guide was most helpful. I am running into some issues out of the gate that have me a bit stumped. I'm currently checkout the following code example from the repo:
https://github.com/adafruit/Adafruit_Ci ... _client.py
In the example we start with:
I'm running into a few issues here that fall outside of what I see in the guides(thus my questions here)
First of all, uart which seems to actually need to be
But thats alright, easy enough. The one that I don't have an avenue towards fixing is that running
halts immediately with the error message:
File "code.py", line 17, in <module>
File "adafruit_ble/__init__.py", line 146, in __init__
RuntimeError: No adapter available
So I find myself wondering(as I've found the class in the init), what constitutes an adapter here and how do I need to modify it to work with the qt py rp2040?
Thoughts? I am unsure how to proceed, and the guides and samples don't seem to cover this.
from adafruit_ble import BLERadio
from adafruit_ble.advertising.standard import ProvideServicesAdvertisement
from adafruit_ble.services.nordic import UARTService
ble = BLERadio()
uart = UARTService()
advertisement = ProvideServicesAdvertisement(uart)
uart = busio.UART(board.TX, board.RX, baudrate=9600)
ble = BLERadio()
- tannewt
`adafruit_ble` is designed to run on an nrf52840 or with an ESP32 coprocessor.
The UART friend predates the adafruit_ble library. The guide for the uart friend is here: https://learn.adafruit.com/introducing- ... art-friend
- plasnid
Aaah I see. So the limitation here is that this is going to be arduino instead of python...then I'll be using the right libraries and will have better success :)
Awesome, thanks :)
Awesome, thanks :)
