Understanding Monochrome OLED Breakouts & STEMMA QT
gallaugher
Post by gallaugher »
I've added I2C to an Arduino Nano RP2040 Connect & have gotten an Adafruit Gator touch to work, added a non-STEMMA Neopixel strand - that lights up, and now I'm daisy chaining a Monochrome 0.91" 128x32 I2C OLED Display - STEMMA QT / Qwiic PRODUCT ID: 4440
to the Gator.
Sample code from this page works:
https://learn.adafruit.com/monochrome-o ... thon-usage
and "Hello World" prints, but I'm not sure of next steps.
If I try to write more text, say use the code below, it seems the old text is overwritten by new text, so anything beyond "H" (used in both text phrases, "Hello World" and "Hi Buddy" has pixels from both words written.
I then thought since inner_sprite was already created, I could just put a:
splash.append(inner_sprite)
in between the two blocks of code where I draw a label like this:
# Draw a label
text = "Hi, Buddy!"
text_area = label.Label(
terminalio.FONT, text=text, color=0xFFFFFF, x=28, y=HEIGHT // 2 - 1
splash.append(text_area)
However, I get an error that this layer is already in a group.
If I repeat all the code that creates and appends the inner sprite, then I get the desired effect - screen blanks, and I only see the second phrase:
# Draw a smaller inner rectangle
inner_bitmap = displayio.Bitmap(WIDTH - BORDER * 2, HEIGHT - BORDER * 2, 1)
inner_palette = displayio.Palette(1)
inner_palette[0] = 0x000000 # Black
inner_sprite = displayio.TileGrid(
inner_bitmap, pixel_shader=inner_palette, x=BORDER, y=BORDER
Do I need to do this - clear the screen or at least the area over any old text each time I want to enter new text, and do I have to completely recreate the TileGrid as above, then splash.append that recreated tile grid, or is there an easier way.
Am I over-complicating things for basic text use? For example, if I want to simply, regularly update the three lines of text in the display, is there a way to purge what's on the display with a simpler command, then start writing out my text?
Thanks for helping me understand how to best use this display in CircuitPython!
J
dastels
Re: Understanding Monochrome OLED Breakouts & STEMMA QT
Post by dastels »
You can change the text of a label to a new value by setting it's text property. That should do it for you.
gallaugher
Worked great, as you can see :)
And I concur with the Nano RP2040
dastels
Post by dastels »
Haha! Good stuff. Have fun.
