Help on syntax and flow
shriphoenix
Post by shriphoenix »
I am from C/C++ background and newbie to python.
I have written a code, need your help to solve the issue...
he below code if written in While True: super loop, no issues at all.. but error comes when i put it inside blinkLED() function... below i the code:
import time
import board
import digitalio
intervalLED = 0.5
led = digitalio.DigitalInOut(board.LED)
led.direction = digitalio.Direction.OUTPUT
ledState = False
previousMillisLED = 1
currentMillisLED = 1
def blinkLED():
    currentMillisLED = time.monotonic()
    if currentMillisLED - previousMillisLED >= intervalLED:
        previousMillisLED = currentMillisLED
        if ledState:
            print("YES")
            ledState = False
        else:
            print("NO")
            ledState = True
        led.value = ledState
while True:
    blinkLED()
I get following error:
Please help me to correct the code..
Regards,
Shri
dastels
Re: Help on syntax and flow
Post by dastels »
Your code sets the value of both currentMillisLED and previousMillisLED. In Python, variables are created when first assigned to in a specific lexical scope. when the code is directly in the loop, that scope is the global scope and all is well. However in blinkLED, the scope if the blinkLED function. This is fine for currentMillisLED since it is limited to the function; creating a new instance each time the function is executed isn't a problem. It is a problem for previousMillisLED however since it has to exist and retain it's value from call to call. There are two ways to fix this.
The simplest, though often frowned upon is to declare previousMillisLED as a global variable. This will cause the assignment to assign to the global previousMillisLED and not create a new instance. Do this at the start of the function:
def blinkLED():
Another way which is functionally sounder, but more cumbersome and potentially not as obvious is to pass in the global previousMillisLED and return an updated value for it (I've changed the name in the function to avoid confusion):
import time
import board
import digitalio
intervalLED = 0.5
ledState = False
def blinkLED(previousMillis):
    if currentMillisLED - previousMillis >= intervalLED:
        if ledState:
            print("YES")
            ledState = False
        else:
            print("NO")
            ledState = True
        return currentMillisLED
    return previousMillis
while True:
    previousMillisLED = blinkLED(previousMillisLED)
shriphoenix
Hi Dave,
Your 2nd approach solved most of the issues however, ledState error still exists.. any solution??
Regards,
Shri
shriphoenix
Hi Dave,
I changed the code like below.. now everything is working...
# Write your code here :-)
import time
import board
import digitalio
intervalLED = 0.5
ledState = False
def blinkLED():
    global ledState
        if ledState:
            print("YES")
            ledState = False
        else:
            print("NO")
            ledState = True
while True:
    blinkLED()
Thank you very much Dave....
Regards,
Shri
