Trying to meld UART P4665 Example w/BLE Keyboard Example
rossini
Post by rossini »
I'm trying to combine the two example codes; goal is to get my distance measurement 'distanceft' onto my phone.
1) CircuitPython code for Adafruit UART Ranging module P4665
by Al Pierce
and...
2) 5-Button Keyboard to phone via BLE (using itsybitsy rather than feather)
Adafruit CircuitPython 6.3.0 on 2021-06-01; Adafruit ItsyBitsy nRF52840 Express with nRF52840
I've gotten each section to function properly when I comment out the other, but could use some clues as to how to pass the value 'distanceft' into the BLE portion so it is sent to the phone when button 5 is pressed, or all the time really(it's jumpered).
I'm assuming it's something like I have two loops and I don't know how to connect them???
Help please; thanks
# CircuitPython code for Adafruit UART Ranging module P4665
# Al Pierce Sept 9, 2020
# Based on Adafruit CircuitPython_UART.py example code
import board
import busio
import digitalio
import time
import adafruit_ble
from digitalio import DigitalInOut, Direction
from adafruit_ble.advertising import Advertisement
from adafruit_ble.advertising.standard import ProvideServicesAdvertisement
from adafruit_ble.services.standard.hid import HIDService
from adafruit_ble.services.standard.device_info import DeviceInfoService
from adafruit_hid.keyboard import Keyboard
from adafruit_hid.keyboard_layout_us import KeyboardLayoutUS
from adafruit_hid.keycode import Keycode
# used for sleep function (but don't use pause function; causes accum count errors -R
# import time
led = digitalio.DigitalInOut(board.D13)
led.direction = digitalio.Direction.OUTPUT
uart = busio.UART(board.TX, board.RX, baudrate=9600)
while True:
    data = uart.read(32)  # read up to 32 bytes
    if data is not None:
        led.value = True
        # convert bytearray to distance in mm
        distancemm = data[1] * 256 + data[2]
        # print distance in mm
        print(distancemm, "mm")
        # compute distance mm to cm
        distancecm = distancemm/10
        # print distance in cm
        print(distancecm, "cm")
        # compute distance cm to inches
        distancein = distancecm/2.54
        # print distance in inches
        print(distancein, "inches")
        # compute distance inches to feet
        distanceft = distancein/12
        # print distance in feet
        print(distanceft, "feet")
        print("")
        led.value = False
# SPlit Here ==========================================================================
# Split Here ==========================================================================
# This example acts as a BLE single key "keyboard" to peer devices (iPhone),
# for testing purposes.
# Attach five buttons (with pullup resistors) to itsybitsy nRF52840
# button 5(a jumper)will send a string "feet" to mobile device or computer
# import items were here; moved up to beginning
# removed button 1-4 code pin & direction since not needed for testing
button_5 = DigitalInOut(board.D5)
button_5.direction = Direction.INPUT
hid = HIDService()
device_info = DeviceInfoService(software_revision=adafruit_ble.__version__,
                                manufacturer="Adafruit Industries")
advertisement = ProvideServicesAdvertisement(hid)
advertisement.appearance = 961
scan_response = Advertisement()
scan_response.complete_name = "CircuitPython HID"
ble = adafruit_ble.BLERadio()
if not ble.connected:
    print("advertising")
    ble.start_advertising(advertisement, scan_response)
else:
    print("already connected")
    print(ble.connections)
k = Keyboard(hid.devices)
kl = KeyboardLayoutUS(k)
while True:
    while not ble.connected:
        pass
    print("Start typing:")
    while ble.connected:
        if not button_5.value:
            kl.write("feet")
            time.sleep(3.0)
    ble.start_advertising(advertisement)
Reason: fixed code block
